Front Brakes / Suspension Upgrade - Chevelle Tech
 3Likes
  • 1 Post By yanniziomas
  • 2 Post By Tommy the Cat
post #1 of 9 (permalink) Old Oct 26th, 18, 11:08 AM Thread Starter
Lightbulb Front Brakes / Suspension Upgrade
I'm getting ready to upgrade my 65 with front disc brakes. I figured since I was going to do that, I am going to ahead and install front coil overs.
Does anyone have any advice or suggestions on other things I should probably go ahead and replace / rebuild since I'm going to have that stuff apart and out of the way? Everything looks close to original. I have never worked on brakes before but there is only one way to learn.
Any help would be appreciated. Trying to stay within budget so I know a complete front end upgrade with control arms etc would be nice but I am trying to locate those $40 or less parts that are only worth replacing if you have to or you are working in that area doing something else.
JRMoore65 is offline
post #2 of 9 (permalink) Old Oct 26th, 18, 11:18 AM
Steering components would be a good idea, check for play etc. Same for bushings, ball joints.
I don’t know your plan and/or budget, but I would be spending $s elsewhere first than coil over shocks.
Clint44 likes this.
yanniziomas is offline
post #3 of 9 (permalink) Old Oct 26th, 18, 12:13 PM
Re: Front Brakes / Suspension Upgrade
Agreed. Forget coilovers if you're on a budget. Coilovers have their place but the majority of builds are probably better off with regular springs and shocks.
Clint44 and -SS454- like this.
70 Camino...Roller
Tommy the Cat is offline
post #4 of 9 (permalink) Old Oct 27th, 18, 4:50 AM
Geoff
Agree with others. Coil overs fix something that ain't broke...
Gtogeoff is offline
post #5 of 9 (permalink) Old Oct 30th, 18, 2:04 PM
There seems to be what I would call "coilover hype"....every car built on a tv show gets them. Many like the height adjustment but that is limited by shock travel.
From what I have read, good ride quality (street) suspension needs good: shocks, springs, sway bar, and bushings. I opted for a suspension package without coilovers.
Sent from my SM-G930T using Tapatalk
jcor12 is offline
post #6 of 9 (permalink) Old Oct 30th, 18, 3:13 PM Thread Starter
Joe,
What package did you go with? Has anyone changed out their steering box? Mine has a lot of play in it.
post #7 of 9 (permalink) Old Oct 30th, 18, 4:07 PM
Originally Posted by JRMoore65 View Post
Joe,
I went with the equivalent of this one:
RideTech StreetGrip Suspension Systems 11245010
I say equivalent because I bought this package for my 1967 camaro. If you like that system, I recommend calling Matts Classic Bowties as he quoted me the best price.
Another benefit of buying a package is that the components have usually been tested and optimized to work together.
jcor12 is offline
post #8 of 9 (permalink) Old Oct 30th, 18, 7:31 PM
Call Marc at SC&C.. I have there Stage three system with a Lee 14:1 its fantastic! It comes with Howe ball joints. After a turn, the steering wheel snaps back to center like a manual..
hydro462 is online now
post #9 of 9 (permalink) Old Nov 1st, 18, 12:17 PM
Joe,
I put an AGR box from Summit on my Ď68. It was listed at $545, but I waited for one of the many $50.00-off deals that Summit runs and bought it for $495. I replaced my A-arms with Global West Suspension arms and all of the steering components with Moog stock replacements. I stayed with stock springs and KYB Gas-Adjust (stock type) shocks.
Without a doubt, the steering box made the driving experience great. Tighter turning and higher effort so it feels more modern.
any4xx is online now
This Thread is more than 478 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
