Brakes randomly go to floor - Chevelle Tech
 9Likes
  • 1 Post By pizzi-man
  • 1 Post By blm
  • 1 Post By ram396
  • 3 Post By OLDED
  • 2 Post By JF74chevelle
  • 1 Post By JF74chevelle
post #1 of 9 (permalink) Old Aug 9th, 18, 11:34 PM Thread Starter
Justin
So I have a weird problem when driving my car and sometimes not every time but I push in the clutch and try and come to a stop the brake pedal will go to the floor. It will not do it if the clutch is not pushed in so that’s why I’m at a loss. But I can pump he brakes and the pressure comes back. I checked the brake fluid and it’s still full. I can’t see any leaks either
JF74chevelle is online now
post #2 of 9 (permalink) Old Aug 10th, 18, 2:19 PM
Re: Brakes randomly go to floor
you might have air in your system or your master is getting ready to take a dump.
HKalin likes this.
Don Pizzi
66 el camino LT1
pizzi-man is offline
post #3 of 9 (permalink) Old Aug 10th, 18, 2:53 PM
blm
Think pushing in the clutch is just a coincidence. I would inspect all the lines for leaks or damage especially the flexible front lines. If all good do a good brake bleed on all brakes. If trouble persists master cylinder would be next suspect.
HKalin likes this.
blm is online now
post #4 of 9 (permalink) Old Aug 10th, 18, 3:13 PM
Ron
Sounds like it may have something to do with the clutch/brake pedal assembly. May want to check and see if there's any play in the pivot point in both pedals.
HKalin likes this.
ram396 is offline
post #5 of 9 (permalink) Old Aug 10th, 18, 10:37 PM
Replace the M/C, and bleed the system.
Dean, JWagner and lucifershammer like this.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #6 of 9 (permalink) Old Aug 10th, 18, 11:29 PM Thread Starter
Justin
MC are cheap enough I might just replace it and bleed the system. I did the drive the car last night and today and it never did it and I tried to make it do it but it didn’t.
post #7 of 9 (permalink) Old Aug 12th, 18, 1:14 PM
what he said☝️
BlakeSixty8 is offline
post #8 of 9 (permalink) Old Aug 12th, 18, 1:30 PM Thread Starter
Justin
what he said☝️
I got one on the way from summit.
OLDED and DUTCH MAX HEADWORK like this.
post #9 of 9 (permalink) Old Aug 15th, 18, 12:18 PM Thread Starter
Justin
New master cylinder from summit, it’s an AC delco. Just bled the system and took it for a drive and it seems to be better than before. The pedal is firmer which I like.
OLDED likes this.
This Thread is more than 658 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
