Chevelle Brake Vacuum Source - Chevelle Tech
post #1 of 10 (permalink) Old Jul 1st, 18, 5:42 PM Thread Starter
I posted this question In the engine section with no luck so I am trying here . Changing from a Holley to stock original Quadrajet Intake setup on my 1971 Chevelle 454 LS5 MT w/ a/c and Ca. Emissions . I need to know where the vacuum source for the brake booster goes to . Im thinking maybe a steel line coming off the carb base or possibly the Intake fitting , and also was the fitting a 2 separate port for the cowl hood and vacuum storage tank ? Any Input would be appreciated , picture would be great .
byf41 is offline
post #2 of 10 (permalink) Old Jul 1st, 18, 6:25 PM
Re: Chevelle Brake Vacuum Source
Look for a vacuum source behind the carb, below the throttle plates.
If you lend someone $20, and never see that person again, it was probably worth it.
Molly's 70 is offline
post #3 of 10 (permalink) Old Jul 1st, 18, 7:00 PM
From the factory, it goes in the boss on intake port #8 that is pointing vertically straight up. 3-port fitting required.
zookpr is offline
post #4 of 10 (permalink) Old Jul 1st, 18, 8:36 PM
Most Quadrajets have a 1/4 inch pipe tapped hole in the rear of the carb at the bottom location. That is the vacuum source for power brakes. Some have the boss that is not tapped.
JWagner is offline
post #5 of 10 (permalink) Old Jul 1st, 18, 9:14 PM Thread Starter
Near as I can tell the vacuum came off the rear of the carb base for the brake booster on 1971 BB , but Im still not certain which Is why Im asking . A couple of aftermarket suppliers offer this line for "all 71-72 BB" engines which appears to source from the carb base . Ive also seen the steel line come off the manifold vacuum fitting but Im thinking this was on a 1970 BB . Anyone have a virgin 1971 LS5 MT that could settle this please ?
byf41 is offline
post #6 of 10 (permalink) Old Jul 1st, 18, 9:17 PM Thread Starter
71-72 All BB
byf41 is offline
post #7 of 10 (permalink) Old Jul 2nd, 18, 5:30 AM
Geoff
Anywhere below the throttle blades is ok. Carb base, the plenum, or an intake runner.
Gtogeoff is offline
post #8 of 10 (permalink) Old Jul 2nd, 18, 3:42 PM Thread Starter
Im wanting to restore It to original , not just what will work . Heres another aftermarket booster line listed for 70-72 BB which appears to connect to the manifold vacuum fitting . This Is why Im confused here .
byf41 is offline
post #9 of 10 (permalink) Old Jul 2nd, 18, 3:46 PM
3/8 line to booster attaches to this fitting. 2 smaller 1/4 ports for AC & Cowl Hood. Not sure on CA emissions. There is a fitting with three 1/4 ports. All are on eBay.
Name:	3-port fitting - Brakes, AC, CI.jpg
zookpr is offline
post #10 of 10 (permalink) Old Jul 2nd, 18, 7:48 PM
Over there.
yanniziomas is offline
This Thread is more than 648 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
