Currie Currectrac UCA's don't adjust short enough? - Chevelle Tech
 8Likes
post #1 of 29 (permalink) Old May 13th, 18, 9:20 PM Thread Starter
I installed my high quality and expensive Currectrac rear UCA's, but they don't seem to adjust short enough. This is as far as they go. I need a much short arm as I run no hop bars which have buggered my pinion angle. Anyone else run into this issue?
-SS454- is offline
post #2 of 29 (permalink) Old May 13th, 18, 11:25 PM
Re: Currie Currectrac UCA's don't adjust short enough?
I havent used the Curries - but I have the UMI adjustable uppers with the roto ball ends and no-hops - with no issues of adjustability to set the angle.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #3 of 29 (permalink) Old May 13th, 18, 11:36 PM Thread Starter
Do you know how short the UMI's will go? These Currectrac's only go 1.5 turns shorter than the stock arms.
-SS454- is offline
post #4 of 29 (permalink) Old May 13th, 18, 11:47 PM
I donít know what no-hops are, but those UCAs worked fine on my lowered 65.
MikeMalibu is offline
post #5 of 29 (permalink) Old May 14th, 18, 12:37 AM Thread Starter
Raise the mounting point of the UCA
-SS454- is offline
post #6 of 29 (permalink) Old May 14th, 18, 10:00 AM
Ryan
The UMI uppers with Roto-joints go 3/4" shorter than stock, if you use a rod end upper control arm it will go up to 1" shorter.
I hope that helps
UMI Performance is offline
post #7 of 29 (permalink) Old May 14th, 18, 5:54 PM Thread Starter
I hope that helps
what is a rod end UCA?
-SS454- is offline
post #8 of 29 (permalink) Old May 14th, 18, 7:01 PM Thread Starter
I talked to Currie and they are suggesting I grind down the ends to allow it to go shorter. Not too happy, but it is a solution.
The other idea I had was maybe trying to move the no hop bars more inward, and drilling a new hole in the diff ribbing. This would pivot the ears towards the front of the car. Who knows how much issues that could cause though.
-SS454- is offline
post #9 of 29 (permalink) Old May 15th, 18, 9:00 AM
Ryan
Like this, when we use a rod end it allows the arm to go shorter than a Roto-Joint because the diameter is smaller.
1968-1972 GM A-Body Adjustable Upper Control Arms Ultimate Arms [4017] - $239.99 : UMI Performance, Inc.
post #10 of 29 (permalink) Old May 17th, 18, 1:45 PM
Andrew
I see nothing wrong with shortening the ends a little to allow the arms to get shorter.
Andrew
VinceS427bb likes this.
1970 GTO Version 2.0
1967 Cougar LSx build
My YouTube Channel
Instagram @projectgattago
andrewb70 is offline
post #11 of 29 (permalink) Old May 17th, 18, 2:34 PM
Clint
Do you really need the no-hop bars, now that you have the adjustable control arms?
RAMBO likes this.
Clint44 is online now
post #12 of 29 (permalink) Old May 17th, 18, 4:43 PM
Ben
x2 just remove the no hop bars and adjust the driveline angles properly with the adjustable upper arms. isn't that why you bought them?
Clint44 likes this.
RAMBO is online now
post #13 of 29 (permalink) Old May 17th, 18, 7:16 PM
I'm assuming the no hop bars are there because the OP is trying to change the instant center of the suspension.
Just adding adjustable upper control arms doesn't change the instant center.
You either need the no hop bars that raise up the rear of the upper control arms or you need relocation brackets for the rear of the lower control arms to lower the rear of the lower control arms.
Either of those would move the instant center to somewhere more appropriate than the factory angles have it at.
1972 Chevelle, 454, 2004r, 3.08
lucifershammer is offline
post #14 of 29 (permalink) Old May 18th, 18, 12:25 AM Thread Starter
The no hop bars were installed by the previous owner. I intend to keep them since they help with traction like Steve said. I bought the adjustable UCA's so I could fine tune my pinion angle in relation to my new transmission angle with my T56.
-SS454- is offline
post #15 of 29 (permalink) Old May 18th, 18, 12:31 AM
Vince
Andrew
this was recommended by manufacturer
should try it
VinceS427bb is offline
