F40/41 rear swaybar holes in trailing arms - Chevelle Tech
 13Likes
post #1 of 17 (permalink) Old Apr 28th, 18, 3:14 AM Thread Starter
I'm looking to fit a Hotchkis rear swaybar to my '67 El Camino, If someone can help I'm chasing the dimensions of the trailing arms and where I need to be drilling holes in them.
Hotchkis instructions say to "unbolt the old one, then install our's and your done" That doesn't help if there has never been one fitted, and no holes
I did see a PDF from an Aim today with the specs but my eyes struggled with the writing. Info on the spacers would be great also as I'll be making my own.
Any help appreciated
rodent4 is offline
post #2 of 17 (permalink) Old Apr 28th, 18, 6:18 AM
Re: F40/41 rear swaybar holes in trailing arms
I don't know if it helps, but someone put a bar on my 1967 El Camino. We got it over 20 years ago, so I don't know the details.
I can take measurements if needed.
Pioneer4x4 is offline
post #3 of 17 (permalink) Old Apr 28th, 18, 7:48 AM
Can you install it on the rear axle and "spot" the proper hole location in the arms that way? Think thats how I did it.
post #4 of 17 (permalink) Old Apr 28th, 18, 8:05 AM
Hank
You also should be using shims between the ends of the sway bar and lower control arms if there is to much clearance so your not pulling in on the control arms.
https://www.npdlink.com/store/produc...-117281-8.html
HKalin is offline
post #5 of 17 (permalink) Old Apr 28th, 18, 12:04 PM
I wouldn't run a sway bar that bolts to a LCA that isn't boxed.
Youtube Channel.
Instagram:
Twitter:
-SS454- is online now
post #6 of 17 (permalink) Old Apr 28th, 18, 1:09 PM
Al
This is the way I lean as well. Sure the spacers will keep the bar from crushing, but by boxing you help eliminate the torsional forces that will twist the control arms. The boxing inserts are dirt cheap and your best bet next to something like much stronger control arms from companies like Hotchkiss. Plus you get to bust out the welder and have some fun. If you don't have a welder, this gives you a good excuse to buy one. WIN/WIN situation.
DUTCH MAX HEADWORK is offline
post #7 of 17 (permalink) Old Apr 28th, 18, 2:23 PM
& Administrator
https://www.lever-family-racing.com/...m-a-body-64-72
scroll down to - Rear Lowers
I would also install/tack weld in the sleeves as shown above.
rodent4 likes this.
Mike is offline
post #8 of 17 (permalink) Old Apr 28th, 18, 3:56 PM
No, not sleeves. boxing plates
https://www.summitracing.com/parts/o...SJYaAh0Z8P8HAQ
post #9 of 17 (permalink) Old Apr 28th, 18, 5:38 PM Thread Starter
rodent4 is offline
post #10 of 17 (permalink) Old Apr 28th, 18, 6:54 PM
sleeves won't do it. they'll keep the arm from collapsing from torquing down the bolt but don't help at all with stiffening the arm. Glen Lever does it right. better than factory and includes the minor mod needed for 12 bolt rears.
post #11 of 17 (permalink) Old Apr 28th, 18, 7:10 PM
All of the resto parts places carry the boxing plate's and those plates will accurately help you to locate the sway bar holes.Or you can buy a pair of lower arms that are already boxed.I added a set of boxing plates to a set of lower control arms with an arc welder and they came out mint.If you can't find measurements anywhere I'll go and measure mine for you.
There are some small holes on the LCA's that don't meet up with anything and you shouldn't use them to locate the sway bar holes.
NickeyChevelle likes this.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is online now
post #12 of 17 (permalink) Old Apr 29th, 18, 9:03 AM
& Administrator
Originally Posted by Tom Mobley View Post
Yeah . that would be better/easier than fabbing the ones shown on the Lever site.
Mike is offline
post #13 of 17 (permalink) Old Apr 29th, 18, 4:02 PM
here's a better URL without all the google marketing crap
https://www.summitracing.com/parts/opg-rcai001
Less than $20.
Kirk's67SS likes this.
post #14 of 17 (permalink) Old Apr 29th, 18, 4:24 PM
Al
What's the mod for 12 bolt rear ends. Just curious because I've never owned a 10 bolt and wasn't aware of the mod to go from 10 to 12 trailing arms.
post #15 of 17 (permalink) Old Apr 29th, 18, 5:00 PM
The driver's side upper control arm is ground off and beefed up to keep it from hitting on the housing.
https://www.lever-family-racing.com/...2_Bolt_001.jpg
