Jeggs Moog 5103K ball Joint? - Chevelle Tech
post #1 of 11 (permalink) Old Mar 6th, 18, 9:27 AM Thread Starter
Noticed the other day that one of the boots on my lower ball joint is kind of fractured, grease not leaking; but it looks like it won't be too long. This is on a 66 with original suspension with ball joints and control arm bushing replaced about 10 years ago. Only change is I replaced the sway bar with a 1 1/4 bar.
The Jeggs site says it made in the usa. Is this a good choice? Car is street driven about 1000 miles a year. Thanks,
Jim_66SS is offline
post #2 of 11 (permalink) Old Mar 7th, 18, 4:35 AM
Geoff
Re: Jeggs Moog 5103K ball Joint?
Moog ball joints that I bought recently [ from Summit ] were made in the other USA, south of the border....
Gtogeoff is offline
post #3 of 11 (permalink) Old Mar 7th, 18, 4:39 AM
Energy suspension used to offer dust boots for ball joints, it might be worth a few minutes to root through their catalog and see if they are still available.
Steve R
Steve R is offline
post #4 of 11 (permalink) Old Mar 7th, 18, 5:57 AM
OUCH! That hurts.
If you lend someone $20, and never see that person again, it was probably worth it.
Molly's 70 is offline
post #5 of 11 (permalink) Old Mar 8th, 18, 9:35 PM
Alex
Was it one of the problem solver ball joints? I know there is an R series that isn't made in the USA.
1969 Chevelle SS --- 468 FTI Level 4 TH400 AFR 290cc's
1997 S10 SS ---LQ9/4l65e
Chevymec is offline
post #6 of 11 (permalink) Old Mar 8th, 18, 10:27 PM
Rame
1000 miles a year? A band aid and a zip tie could do the job.
sampoerna415 is offline
post #7 of 11 (permalink) Old Mar 9th, 18, 5:00 AM
Geoff
Alex not 100% sure, but I think it was just regular BJ. It did have serrations around the base, if that helps.
Gtogeoff is offline
post #8 of 11 (permalink) Old Mar 10th, 18, 9:48 AM
Alex
Geoff, looks like I need to start checking my boxes better. I found this link... Where are Moog parts made? The answer may surprise you! - Suspension.com
I have 4 Moog's for my S10 in the shop that I am about to go check.
Chevymec is offline
post #9 of 11 (permalink) Old Mar 10th, 18, 6:43 PM
Alex
Just went out and checked mine. All made in the USA.
Sent from my SM-G930V using Tapatalk
Chevymec is offline
post #10 of 11 (permalink) Old Mar 11th, 18, 5:07 AM
Geoff
Curious now, so had a look.
Moog K5144 BJs, Made in mexico. Moog bushing Kit, Made in mexico.
Bought from Summit last year.
Gtogeoff is offline
post #11 of 11 (permalink) Old Mar 11th, 18, 11:34 AM
Alex
Jim_66SS , to answer your question Yes Moog "problem solvers" are good pieces. I will not use a cheap store brand in anything anymore after putting cheaper ones in a dodge truck and having both lowers snap after about 7 months. I have had 0 returns after using Moog's. Also, if you do just want to replace the boots, Rockauto has a set for your car that is under $10 shipped. Has both upper and lowers in the kit.
Chevymec is offline
This Thread is more than 710 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
