C4 Front Brakes on a 65? - Chevelle Tech
post #1 of 10 (permalink) Old Jan 23rd, 18, 7:59 PM Thread Starter
Devin
I'm pretty sure I've seen this done before, searched threads and couldn't find it. A buddy upgraded from 12 to 13" rotors and calipers on his 92 Vette. He's offering us his take offs for my son's 65 which currently has drums in front. Is it do-able, and if do what is needed?
Thanks,
Devin
Just an El Camino
Son's build:
My never-ending project:
64SS427 is offline
post #2 of 10 (permalink) Old Jan 24th, 18, 6:34 PM
Ray
Re: C4 Front Brakes on a 65?
I used C4 front brakes on a Chevelle years ago. You need a conversion bracket.
I made my own.
But these may work for you: '67-69 C4 brake upgrade conversion brackets
rortwein is offline
post #3 of 10 (permalink) Old Jan 24th, 18, 7:34 PM
Originally Posted by rortwein View Post
I used C4 front brakes on a Chevelle years ago. You need a conversion bracket. I made my own. But these may work for you: '67-69 C4 brake upgrade conversion brackets
Thanks for posting that link, Ray. I've been looking for someone who makes those brackets.
Clint44 is offline
post #4 of 10 (permalink) Old Jan 25th, 18, 5:43 PM
Ray
Quite welcome Clint. I never used them but a lot of the guys on the S10 forum have recommended them over the years.
rortwein is offline
post #5 of 10 (permalink) Old Jan 25th, 18, 5:50 PM
Ray, did you use a 12" or 13" rotor, on your car? If it was the latter, where did you get them?
Clint44 is offline
post #6 of 10 (permalink) Old Jan 28th, 18, 8:58 AM
Kevin
Baer uses C4 calipers on their older Track 4 set up with 13" vented/cross drilled rotors. The adapter bracket for the calipers looks to be something you could whip out pretty quickly with some aluminum stock. Their's of course is CNC'd.
"If you're not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
Inglese 50mm 8 stack injection
FAST XFI Street
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #7 of 10 (permalink) Old Jan 28th, 18, 12:39 PM
Baer doesn't offer anything with a PBR caliper anymore or I would buy that set-up. My 69 Elco had it and I would like to duplicate it, for my 70. Flynbye Performance sells the caliper brackets so I need to find out what hub and 13" rotor I would need.
Clint44 is offline
post #8 of 10 (permalink) Old Jan 29th, 18, 6:28 PM
Ray
I used standard 12" GM corvette rotors on mine. Also used a stock Chevelle Hub assembly that I turned down slightly so it fit inside the rotor.
Made my own bracket when I did it.
rortwein is offline
post #9 of 10 (permalink) Old Jan 29th, 18, 6:30 PM
Ray
Oh IIRC (it's been a lot of years) I believe you can use either rotor assembly 12 or 13 just use the corresponding caliper mounts/baskets. I had both back then on hand. But my wheel package required the 12" ones. Again if I am remembering it correctly.
I used all GM parts other than my brackets.
rortwein is offline
post #10 of 10 (permalink) Old Jan 29th, 18, 6:35 PM
Thanks for the info, Ray. I think I've got a pretty good idea on how to do this, now.
Clint44 is offline
This Thread is more than 896 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
