4 wheel disc recommendations - Page 2 - Chevelle Tech
 11Likes
post #16 of 25 (permalink) Old Nov 27th, 17, 9:53 PM
Re: 4 wheel disc recommendations
Not bashing their parts Tom but do not rely on the parking brake holding the car stationary. I have had them before. Also note that the rear caliper bracket does not have any provision for securing the rotor against the rotational force of braking over the centerline of the rotor. They rely on the slide pins for that. It is not that I race or autocross my cars but I do want them to have well engineered brakes since my life and others depend on it. Plus this style of brakes was developed in the mid 70's, there is better technology available.
GM rear disc with the caliper applied e brake. Notice the support for the caliper directly over the rotor. It also stabilizes the caliper when moving on the slide pins.
Aftermarket rear disc with the caliper applied e brake.
63 Nova wagon
Philip is offline
post #17 of 25 (permalink) Old Nov 28th, 17, 8:17 PM
I have the KISS kit on my 65 Elky. A-body front discs from a 70 Cutlass (same as Chevelle). Rears are from a 94 Z-28. All are basically bolt directly on to the existing axles. Had to modify the rear E-brake cable brackets - not a big deal, and connect the old to the new brake cables in mid-car. And applying the pressure with a GM hydra-boost from a 1 ton van. Using the pump and reservoir from the same van (dual drainbacl nipples ino the reservoir. Stops with ease and still has feel to the pedal.
Philip likes this.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #18 of 25 (permalink) Old Nov 29th, 17, 10:06 AM
Sounds like a nice set up Ed.
63 Nova wagon
Philip is offline
post #19 of 25 (permalink) Old Nov 29th, 17, 4:50 PM
I agree with Phillip 100% on that style of GM e brake being garbage. I didnít even bother ordering my calipers with that set up. I just opted for no e brake for now. I know some of you guys have to have your cars inspected so you have to have one. Or the manual trans guys also. I will eventually change mine out to something with an e brake, but I would like the drum style, that goes inside the rotors. Also I have a Moser rear with Ford ends on it, so I need to find what will work best for me.
70CHEVELLE396 is offline
post #20 of 25 (permalink) Old Nov 29th, 17, 5:21 PM
Aaron
Wilwood has a great ID tool on their website to determine what rear kit fits your bearing end and flange stick out. I used their rear discs with internal parking brake on the 9Ē in my Ď72 and couldnít be happier.
70CHEVELLE396 likes this.
Donuts on your lawn.
turbobrick is offline
post #21 of 25 (permalink) Old Nov 29th, 17, 5:26 PM
Thanks, I have seen that. I will most likely end up with a wilwood setup, just for now I keep finding other areas of the car to throw money at!
post #22 of 25 (permalink) Old Nov 29th, 17, 5:27 PM
Wilwood, Baer and Kore3 are all good products just a little high priced and usually more brake than most street driven cars need.
63 Nova wagon
Philip is offline
post #23 of 25 (permalink) Old Nov 29th, 17, 7:00 PM Thread Starter
Michael
I like the sounds of your set up, I have a hydroboost out of a 06 3/4 ton, only problem the square nut is broken, can't seem to find one. I imagine the 94 z's are probably easy enough to find, the early 70's maybe not so much?
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #24 of 25 (permalink) Old Nov 29th, 17, 8:34 PM
jackie
Originally Posted by Mikes64 View Post
As the title says I'm looking for recommendations for 4 wheel disc conversion. I have a hydro boost mc, not sure if I want to go that route, not very eye appealing, but not opposed to it. Will likely have Fatman 2" drop spindles, and running a 6.0L. Just looking for options.
As I get older, I prefer complete kits. My Malibu has the Wilwood 4 wheel disc conversion, (Ford ends on the 12 bolt to eliminate C-Clips), and a Hydratech Hydraboost.
The Wilwoods look good with 15 inch wheels.
https://www.chevelles.com/forums/atta...1&d=1512005633
https://www.chevelles.com/forums/atta...1&d=1512005784
ID:	498922   Click image for larger version
jackie schmidt is offline
post #25 of 25 (permalink) Old Nov 29th, 17, 8:48 PM
I am having my rear drums changed to disc when changing my rear gears. This is the email i received from the shop in regards to installing these brakes:
https://www.summitracing.com/parts/sum-bk1623
"For the rear disk brakes, I really don't like that style of caliper. Getting the parking brake adjustment correct so the piston travel is right, is a really time consuming process. To install them, I would charge $735.00. Now I have a Wilwood rear disk brake kit that has used calipers and brackets, part number*https://www.summitracing.com/parts/wil-140-9315-r The customer changed his mind on what calipers he wanted. They only have 600 miles on them. The rotors are new. I can sell these for $550.00. They will need parking brake cables https://www.summitracing.com/parts/lok-ec-81fu*and brake hoses https://www.summitracing.com/parts/w...odel/chevelle* .
Labor to install this kit is $330.00"
Joe Sweeting
1970 Chevelle SS (Candian built)
Holley Sniper EFI
Classic Auto Air A/C
American Auto Wire Classic Update
Hermosa Retrosound head unit
454, TH400 Gear Vendors
US Navy Diver - Active duty
joesweeting is offline
This Thread is more than 655 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
