Brake system pressure test idea - Chevelle Tech
 3Likes
  • 1 Post By Bart_Swisher
  • 1 Post By zombie1969
  • 1 Post By Tom Mobley
post #1 of 11 (permalink) Old Aug 29th, 17, 10:56 AM Thread Starter
Lightbulb Brake system pressure test idea
OK guys, crazy idea time. Spent a lot of time and money on my resto. (Year 5) I don't want to mess it all up with brake fluid leaking everywhere.
Brand new brake system, soup to nuts. There's bound to be leaks. So, here's my idea.
I want to use nitrogen or argon thru a high pressure regulator (800 psi max), to pressurize the system at the distribution block.
Check for leaks with soapy solution. Test the rear, then test the front.
I'm not trying to replace a liquid with a gas, just trying to pressurize the system to appropriate levels and check for leaks without corrosive brake fluid.
No master cylinder, just start at the dist. block.
I have access to equipment similar to what's used in HVAC work.
Fabricating fitting adapters for testing in not an issue.
Any comments? (Good, Bad or Ugly?)
_______________
1970 SS/396 5 speed
Johnnyfixit is offline
post #2 of 11 (permalink) Old Aug 29th, 17, 4:15 PM
Bart
Re: Brake system pressure test idea
No offense, but it sure seems like a lot of work that can be avoided by simply using another set of eyes and a couple of rags wrapped around the fittings. I have found that the trick with brake lines etc is to tighten it, loosen it, re-tighten and you are all set. I spent 5 years on my build as well so I understand wanting to keep brake fluid off of fresh paint. But even with the testing you are suggesting, you are still going to have to deal with fluid on the parts when you bleed the system anyway.
RAMBO likes this.
Bart_Swisher is offline
post #3 of 11 (permalink) Old Aug 29th, 17, 6:53 PM Thread Starter
Bart, thanks! I do tend to overthink things. And as you said, I still have to bleed them anyway.
_______________
1970 SS/396 5 speed
post #4 of 11 (permalink) Old Aug 29th, 17, 8:06 PM
AKA Zombietroll
You don't work for the government by any chance do you?
shovelrick likes this.
zombie1969 is offline
post #5 of 11 (permalink) Old Aug 29th, 17, 8:09 PM
Hank
You can always use silicone fluid. That's what I used in mine and I'm glad I did because the combination valve leaked about 1 day after I put the fluid in. The valve was on the frame rail and when I went to replace it the fluid went all over the place.
HKalin is offline
post #6 of 11 (permalink) Old Aug 29th, 17, 8:46 PM
John, please feel free to ignore Zombies nasty remark. It's not really personal, just the way he interacts with the world.
davewho1 likes this.
post #7 of 11 (permalink) Old Aug 29th, 17, 9:10 PM
rick
I'm an a/c guy to, I thought the gov thing was funny but like was said just do the norm, over thinking gets me into problems
shovelrick is online now
post #8 of 11 (permalink) Old Aug 29th, 17, 9:27 PM
I would just use DOT5 brake fluid and call it a day. Never have to worry about drips or paint again. I have always used it and never had any problems, especially if the car is garage kept.
1969 SS396 Convertible
Bob Tiley is online now
post #9 of 11 (permalink) Old Aug 29th, 17, 9:37 PM
AKA Zombietroll
Please elaborate on how my remark was nasty and not just light humor as intended. And when your done please explain how your remark wasn't offensive in any way.
post #10 of 11 (permalink) Old Aug 29th, 17, 10:29 PM
Troy
Why not just pull a vacuum and see if it holds?
66 CHEVELLE
senna is online now
post #11 of 11 (permalink) Old Sep 1st, 17, 9:43 AM
How about:
" Lets not make this task difficult, With some thinking and Engineering,
We can make it dam near impossible ".
Robinls5 is offline
This Thread is more than 1001 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
