Front End Lift - Chevelle Tech
2006 General Tech Forum from 2006
 3Likes
  • 1 Post By Spar
  • 1 Post By Derek69SS
  • 1 Post By Philip
post #1 of 12 (permalink) Old Aug 11th, 06, 7:06 PM Thread Starter
Front End Lift
I'm trying to go old school and not lower my Chevelle but raise it in the front.
But Im having a hard time finding anything that will lift it 2". Everyone has stuff to lower 2" but not lift. I'm told to get a spring from ? car and that will be what I want instead of those spring nuts that you put between the springs to raise.So what spring out of what car will give we what I want.
Thanks for all who help me .Or if anyone has a better way?
Spar
NickeyChevelle likes this.
Spar is offline
post #2 of 12 (permalink) Old Aug 11th, 06, 7:09 PM
"The Stig"
Re: Front End Lift
www.coilsprings.com can hook you up with whatever you're looking for.
There are some geometry issues caused by raising the car, but if that's what you really want, you'll need edelbrock no-hop bars in the rear, and an upper ball-joint spacer in the front.
Derek Kiefer, member of Minnesota's
Derek69SS is offline
post #3 of 12 (permalink) Old Aug 11th, 06, 10:42 PM
Re: Front End Lift
First determine if your car is at stock ride height. If the springs are sagging just replacing with new stock coils will raise the car.
I raised a 68 up about 2 inches over stock ride height by using big block springs in the front and wagon springs in the rear. There is also a thick rubber spacer available that goes in the top spring pocket. Anything inserted in between the coils is trouble waiting to happen.
Saltherring likes this.
63 Nova wagon
Philip is offline
post #4 of 12 (permalink) Old Aug 12th, 06, 12:27 AM
Re: Front End Lift
JC Whitney high lift front springs. Ball joint spacers. They sell the BJ spacers new made on E-bay. I PMed you. Josh
mac762 is offline
post #5 of 12 (permalink) Old Aug 12th, 06, 8:22 AM
Re: Front End Lift
i guy on ebay sells spacers that will lift the front 2inches.
Ryan's malibu is offline
post #6 of 12 (permalink) Old Aug 13th, 06, 12:56 AM
Re: Front End Lift
I have a set of those spacers too. The horse shoe looking ones that are aluminum.
mac762 is offline
post #7 of 12 (permalink) Old Aug 13th, 06, 7:48 PM
Re: Front End Lift
ttt
mac762 is offline
post #8 of 12 (permalink) Old Aug 15th, 06, 6:08 PM
Re: Front End Lift
We'll see if this works and I have others. Later--Josh
mac762 is offline
post #9 of 12 (permalink) Old Aug 15th, 06, 6:16 PM
Re: Front End Lift
Here's another one. This one is done by springs and not the straight axle like the El Camino. I hope RATuned doesn't mind me showing you his Chevelle. later Josh
mac762 is offline
post #10 of 12 (permalink) Old Aug 15th, 06, 6:17 PM
Re: Front End Lift
Aren't those headers wicked?
mac762 is offline
post #11 of 12 (permalink) Old Aug 17th, 06, 6:06 PM
Re: Front End Lift
Nobody likes the Gasser style anymore? Ashamed to admit it in this day of drop spindles and lowering springs? Don't be the movement grows. Later days. Josh
mac762 is offline
post #12 of 12 (permalink) Old Mar 9th, 18, 7:44 PM
Re: Front End Lift
what kind of springs? trying to get my 69 up that high, got a 502 in her n50s on the rear 15x10, would love to have that stance
breeze7423 is offline
Old Mar 9th, 18, 8:02 PM
NickeyChevelle
This message has been deleted by NickeyChevelle.
This Thread is more than 856 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Front End Track Width 67 Nevada Chevelle Brakes, Suspension & Steering 7 Apr 20th, 06 11:29 AM
71 Front end hardware Skeeveman Body Shop 3 Feb 17th, 06 12:15 AM
front and rear end lowering p-hanny Brakes, Suspension & Steering 2 Oct 12th, 05 8:00 PM
72 Front End Conversion 71Avido Body Shop 2 May 6th, 05 4:56 PM
70 Malibu Door Alignment Help Chevellehell Body Shop 2 Oct 10th, 03 10:34 AM
You may not post new threads
You may not post replies
