Lower Ball Joint Boot Install trick??? - Chevelle Tech
2007 General Tech Forum from 2007
 3Likes
  • 1 Post By SS70ElCaminoOwner
  • 1 Post By Steve Blok
  • 1 Post By 71350SS
post #1 of 13 (permalink) Old Apr 2nd, 07, 12:07 AM Thread Starter
OK, so it cain't be Rocket Surgery BUT....
I've already had my lower ball joint pressed into the A-Arm. I'm trying to get that damn grease-holdin(actual function, not a curse word) boot seated on the joint. It's a Moog, w/ a steel ring sealed inside the rubber. Seems like if I get 1 side seated, the other side pops off. I don't see a recessed area or anything on the balljoint base for the boot ring to latch onto. Is there a special trick/tool for this?
I feel like a real ass for asking such a simple question, but I'll be damned if I can get this thing to stay put. I don't wanna screw up the rubber with multiple screwdrivers trying to pry it into place.
cooter95206 is offline
post #2 of 13 (permalink) Old Apr 2nd, 07, 12:47 AM
Brett
Re: Lower Ball Joint Boot Install trick???
I may have had the same issue. I could not get the metal ring to fit over the moog rubber. My metal seat went on the outside. The moog boot is so big, I figured you must just run it without the metal seat. It seems to work fine as the spindle forces it and holds it down. I could be wring but I could not get that ring on. Also the moog boot does not have a lip for the metal to hold onto. Did I make a mistake? The grease still looked pretty clean last time I greased it so I think it is protected just fine.
1968 Camino Custom
468, TKO600, 3.73:1
Pic of Car:
Pic of 468:
1966 Triple Black Chevelle
327, TKO600, EFI, 4.11:1
Pic of Car:
Brettd85 is offline
post #3 of 13 (permalink) Old Apr 2nd, 07, 1:19 AM
P evaD
I did what Brett said, it's all I could get. Now it has opened up some, and it bothers me everytime I go under the car.
Dave P.
1971 Chevelle
11.44 @ 118.43
Leading by example.
Curing cancer, one body panel at a time.
My Chevelle
home page
Dave is offline
post #4 of 13 (permalink) Old Apr 2nd, 07, 1:36 AM
Brett
Thats annoying, mine are still in great shape. I guess you should replace it or just grease more often...
1968 Camino Custom
468, TKO600, 3.73:1
Pic of Car:
Pic of 468:
Pic of Car:
Brettd85 is offline
post #5 of 13 (permalink) Old Apr 2nd, 07, 6:50 AM
Glenn
The Moog boot is particularly hard to put on. I have a piece of pipe that fits over the boot but sits on the rubber lip that contains the metal ring (a LARGE socket would do the same thing). I pop one side on and then use a hammer to drive the other side down onto the ball joint. It is best to do this before you put the grease fitting in the bottom of the ball joint. Note there is a little notch on the under side of the rubber boot that goes to the inboard side (there is some small writing on the boot that says mount inboard). This is a grease release and allows the excess grease to come out of the boot away from your brakes.
HKalin likes this.
Glenn R. Lever
Rochester, New York 14617-2012
My Cars
Control arm Info
SS70ElCaminoOwner is offline
post #6 of 13 (permalink) Old Apr 2nd, 07, 9:54 AM
make sure you lube up the rubber boot. I just use penetrateing oil. Then pull it on with my fingers by working my way around the boot.
LKN BCK likes this.
Steve Blok is offline
post #7 of 13 (permalink) Old Apr 2nd, 07, 9:58 AM
I also used a piece of pipe to drive it on but that was after I ruined a boot and had to buy another.
[[url]
Rick Bandy is offline
post #8 of 13 (permalink) Old Apr 3rd, 07, 3:37 AM
I used a pipe that matched the diameter of the perimeter of the boot and hit on the ring part. Worked but not perfect as the pipes edge is still sharp enough to cut into the boot no matter where it contacts.
I even tried a small socket and just tapped around till I got it seated. That worked too but I put a small pinhole in one of my boots on accident. I didnt mind, the amount of grease inside will render any small amount of water that gets in there harmless, plus greasing it every oil change. It isnt really a big deal.
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
Chris R is offline
post #9 of 13 (permalink) Old Apr 4th, 07, 10:52 PM
The middle adapter tube from the lower ball joint press (OTC brand,all the others are just clones) is the perfect size to push the lower ball joint boot on the ball joint after its been installed in the control arm,been doing it that way for more years than I care to remember.
Jonh72SS likes this.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #10 of 13 (permalink) Old Apr 9th, 07, 5:39 PM
I've read that an appropriately sized piece of PVC tubing works best ...with the ID deburred as to not tear the boot.
Bilster is offline
post #11 of 13 (permalink) Old Dec 21st, 17, 3:15 PM
I realize this is an old thread but I found it when trying to solve this issue so I'm gonna post to maybe help others.
I was having the same issue on my 67 C10. A 2" PVC was the perfect fit and I greased the boot and ball joint and still managed to to damage the hard ring at the bottom of the boot. In frustration I cut the metal ring in the boot and wire tied it on like I do with my dirt bike handle bar grips. This reminded me of the old trick for putting on grips. Spray the inside with hairspray. I tried this on the other side and it went right on.
C10tony is offline
post #12 of 13 (permalink) Old Dec 21st, 17, 3:51 PM
C10tony is offline
post #13 of 13 (permalink) Old Dec 21st, 17, 3:58 PM
"Wild Bill"
Posting the same thing twice doubled your Post count
1967 Camaro SS-Gen I
2017 Camaro RS-Gen VI
2019 Cadillac XT5 AWD
1990 Ford F150 XLT Lariat
BillsCamino is offline
This Thread is more than 720 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Brakes and Front End Project Smittie Brakes, Suspension & Steering 18 Apr 15th, 07 11:20 PM
Ball joint install?............. ak69 Brakes, Suspension & Steering 3 Jan 21st, 06 9:14 PM
lower ball joint fit problems EddieT 1999 -- 3 Jan 8th, 00 11:04 PM
lower ball joint R&I Hunter 1999 -- 4 May 18th, 99 8:29 PM
Anyone installed lowering springs on their early Chevelle or El Camino? Bill64EC 1999 -- 5 Mar 24th, 99 4:44 PM
You may not post new threads
You may not post replies
