OK to use rubber fuel line for power steering return line? - Chevelle Tech
2010 General Tech Forum from 2010
 2Likes
  • 1 Post By The Old Reliable
  • 1 Post By Philip
post #1 of 8 (permalink) Old Sep 18th, 10, 8:58 AM Thread Starter
john
Is it ok?My return hose feels real mushy and I want to replace it,what is the right type of hose?Thanks
70 chevelle 468 2 bolt mains,steel crank,srp 14cc
pistons .049 heads 2.19/1.88 manley/116cc,harland sharp roller rockers,Cam 501/527,214/224 at .050.air gap 750 double pump .3.73 posi.9.6:1 compression Th400-Hughes 3,000 stall speed bm holeshot converter. Best time 12.2
job68327 is offline
post #2 of 8 (permalink) Old Sep 18th, 10, 9:31 AM
Re: OK to use rubber fuel line for power steering return line?
Best to replace your mushy PS return hose with a new PS return hose.
But, yes, you could use fuel line.
The reason I wouldn't is: fuel is cool, PS fluid is hot, and
heat breaks down rubber. All rubber hose is not created
equally, i.e., for all possible uses.
HTH
Steve R likes this.
The Old Reliable is offline
post #3 of 8 (permalink) Old Sep 18th, 10, 10:31 AM
The same places that sell fuel line also sell PS return line. It is rated for higher pressure and to withstand the heat and oil.
Steve R likes this.
63 Nova wagon
Philip is offline
post #4 of 8 (permalink) Old Sep 18th, 10, 10:37 AM
Doug Davis
Yea, the pressure is what you need to be concerned about. Not just what's flowing through it.
66 Chevelle
350/400 Turbo
12 Bolt Eaton Posi w/3:73's
Team Chevelle Member # 3540
davis95 is offline
post #5 of 8 (permalink) Old Sep 18th, 10, 3:44 PM
Derrick
it only costs about $3 to buy the proper PS return hose...
-Hank Hill
novaderrik is offline
post #6 of 8 (permalink) Old Jun 29th, 17, 7:38 PM
where do i buy a ps return line hose
Rose818110 is offline
post #7 of 8 (permalink) Old Jun 29th, 17, 7:41 PM
Call you local auto parts store. They should have it in stock.
Steve R
Steve R is offline
post #8 of 8 (permalink) Old Jun 30th, 17, 5:29 AM
Geoff
The return line is low pressure & it empties into an atmospheric chamber. High pressure feed line exits the pump through an orifice 3/16" or less diam & returns via 3/8"hose. The hose needs to be able to withstand the high temp of the returning fluid.
Gtogeoff is offline
This Thread is more than 691 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
