Decided to buy this car instead any advise - Chevelle Tech
post #1 of 7 (permalink) Old May 6th, 05, 10:37 PM Thread Starter
Your input was greatly appreciated in my recent post about purchasing that 70 SS (see recent post). I still never got the full story from the guy, but when I started asking the RIGHT questions, he got weird on me. I bailed. Anyway, on to another one, right. I am going to look at this car. It needs a lot more work, but I am up to it. Does anyone see anything weird in these pics. What is up with the steering wheel. Was that an optional wheel? I would REALLY appreciate any help in keeping me out of any danger. Thanks again guys!!!
If someone can help with the link. It is ebay item #4546591527
brickyard69 is offline
post #2 of 7 (permalink) Old May 6th, 05, 10:46 PM
Re: Decided to buy this car instead any advise
Brickyard, my friend looked at this car. It was on ebay a few weeks ago. I think the reserve was $16k last time. Now it's 12k. It needs A LOT of work. There's major rust in the 'A' pillar which is not mentioned. The cowl hood is dented. Notice they only show underside picture of hood. I'd be cautious. Steering wheel is from 71 or 72.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4546591527
Tim
Team Chevelle #1877
'70 SS - L34/M20 (undergoing frame off)
70Z15 is offline
post #3 of 7 (permalink) Old May 6th, 05, 10:49 PM Thread Starter
Tim:
Thanks for the advise, every little bit helps. I am going to look at it in the am, I'll keep an eye out for those things
post #4 of 7 (permalink) Old May 6th, 05, 11:15 PM
Red face Re: Decided to buy this car instead any advise
i think thats a pretty high price for a basket case.don't know if body is bent or tweaked from been taken off of frame?i have had one purchase off ebay on a car,was not satisfied with purchase.really look at it before you by.
big bubba is offline
post #5 of 7 (permalink) Old May 6th, 05, 11:46 PM
Looks like a MAJOR project to me ... wont be cheap to get it back together.
TC Member # 5462
70 Chevelle SS/396 4-Speed
DYNO RWHP: 364HP @ 5200 RPM / 426 Torque @ 3500 RPM
Birddog1970 is offline
post #6 of 7 (permalink) Old May 7th, 05, 1:16 AM
Steve Johnson
Brickyard, I hope you take this in the right way, run as fast as you can. For every problem that you can see there are probably five more that you don't see. Be patient and wait for the right thing. Many of the people on this board have waited years to get what they want and most were better off for waiting.
1970 SS with a .030 over 454 LS6 crate engine, 14096188 open chamber rect. cast iron heads, 3933163 intake, Quick Fuel Q850PV, Summit 110gph FP, Holley 12-803 fuel pressure regulator set to 6.5 psi, Bullet cam (238/245 @ .050, lift 540/540, LSA 109), Gm HEI 93440806, TH400, FTI 3500 convertor, Hedman headers, 2.5" exhaust with H-pipe, Pypes Race Pro mufflers, 3.55 gears, KYB gas shocks, UMI rear adjustable upper control arms and UMI boxed lowers, pinion angle negative 1-2 degrees), 225/70/14 Cooper Cobra GT's and M/T Pro Bracket Radials, timing total 37 degrees. Best 1/4 mile pass 1.700 60', 11.841 @ 111.73 mph
Steve Johnson is offline
post #7 of 7 (permalink) Old May 8th, 05, 11:07 PM
Forget it completely. You could buy a $10,000 to $15,000 Chevelle and be way better off. This looks like a nightmare, completely far gone to even consider. Do you want a real SS, or a clone? Either way, wait until a better deal comes along. I would bet that you could put $25k into this thing and it would still be worth less than what what you paid and put into it.
SSteve is offline
This Thread is more than 5334 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
How did you find your Chevelle? Chevelle408 Bench Racing 61 Feb 23rd, 08 2:17 PM
Low on fluid or is this normal for a high stalled car? Junkyard Dawg 2005 0 May 1st, 05 8:37 PM
Car show at Bass Pro Shop in Katy, TX? gigem Team Chevelle Cruiz-ins 3 May 1st, 05 9:53 AM
