Found a 67 ss - Chevelle Tech
post #1 of 6 (permalink) Old May 4th, 05, 8:03 PM Thread Starter
Found a 67 ss
just located a 67 ss where can it get info to read the vin it is as follows
ST 67-13817 Bf07477
TR 731 FF
62783 030084
inside the drivers door jamb is
1381777156968
rdkvel667 is offline
post #2 of 6 (permalink) Old May 4th, 05, 9:04 PM
Re: Found a 67 ss
From what I can figure, it sounds like a real SS, with Blue exterior, and blue interior
396/Turbo400/3000rpm stall converter
396/Turbo 400/4:10 Posi/Frame Off Restoration
396/4 spd/3:31 12 bolt posi
Black 1970/LS5 454/4 spd/ 3:31 Posi
tireburner396 is offline
post #3 of 6 (permalink) Old May 4th, 05, 9:25 PM
Re: Found a 67 ss
Marina blue with bright blue buckets seats.
67ss is offline
post #4 of 6 (permalink) Old May 4th, 05, 9:30 PM Thread Starter
Re: Found a 67 ss
how do yall tell that buckets and paint color
post #5 of 6 (permalink) Old May 4th, 05, 10:49 PM
leo
Re: Found a 67 ss
and assembled in the Fremont, Cal assembly plant, the last 7 is most likely a Z, which denotes Fremont assembly as well as the BF in the sequence number.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #6 of 6 (permalink) Old May 5th, 05, 7:53 AM
Dale
Re: Found a 67 ss
Fisher Body plate:
TR 731 is the interior trim code for Med. Bright Blue Imitation Leather bucket seats (bench seat same color is coded 729).
FF is paint code for lower then upper body color. "F" is Marina Blue in 1967.
On the ST(yle), 138 is a SS396 series and 17 is the model, 2-dr sport coupe.
BF is for Fremont, CA assembly plant.
07477 is the Fisher Body number
62783 ~ Factory data processing tracking codes and are no significance
030084 ~ Fremont did not list options on the body plate like some other plants in 1967 but this data processing number appears on the original trim broadcast sheet that would accompany the car during assembly identifying various options such as tinted glass, trans type, seat belts, maybe radio and/or antenna option, etc.
There should also be a body date code just above the 67-13817 something like 07A or 07B since this is an early July car.
VIN
13817 - SS396 series (138)/2-dr sport coupe model (17)
7 ~ model year
7 ~ as noted, should be the letter "Z" for Fremont.
156968 ~ sequence number for Fremont starting with #100001 meaning yours was the 56,968th Chevelle (of all series/models) assembled at Fremont.
If you have a clear photo of it, I'd like to include it in a Reference Guide I'm working on for 1967 Chevelles. See this web page for more information.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
This Thread is more than 5511 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Found another roller... SS_Sean 2004 3 Apr 21st, 04 5:23 PM
Pull pan on newly built 2004r and found this... ZZ4U 2003 1 Apr 29th, 03 11:12 PM
I Found A Cheap Converter malibu man 2002 8 Sep 12th, 02 8:09 PM
LS-6 Convertible found in a Garage-FAKE mr70 2002 9 Apr 30th, 02 12:15 AM
