'70 Chevelle Decode Please - Chevelle Tech
post #1 of 12 (permalink) Old Mar 18th, 05, 10:21 AM Thread Starter
Nate
I finally got off my butt and grabbed some of the numbers off our Chevelle. Car was built the 3rd week of February and the VIN is 136370R212221. Need some help with the decode, please:
Engine Block: T0202CRQ 10R212221
Rims: looks like - M3(?) 2 [valve stem] 5 A0
(Also what looks like a lower case "o" under the M3)
I think I asked Dale this question before, but where on the TH400 and rear-end would I find a stamp?
Thanks,
Denita & Nate
TC #2423
TripleWhiteSS454 is offline
post #2 of 12 (permalink) Old Mar 18th, 05, 1:18 PM
Re: '70 Chevelle Decode Please
I can help with some of it.
136370R212221
1 = Chev div of GM
3637 = Malibu, 2 dr., Coupe, 8-cyl
0 = 1970
R = Arlington Texas
212221 = assy seq. # starting at 100,000
T0202CRQ
T = Tonawanda engine plant
0202 = Feb., 2nd week
CRQ = 1970 454, mated to turbo-400, 360hp, LS5
10R212221 = partial vin derivitive
1 = Chev div of GM
0 = 1970
R = Arlington Texas
212221 = last six digits of VIN of car engien was originally installed in- Congratualtions you have a matching #'s engine!!!
AO on rims = 1970 SS wheels
Don't know where to look on tranny
Rear end should be on passenger axle tube, facing forward, just out from pumkin.
Steve Strasemeier (70SS 396, Fathom Blue/White Stripes)
Steve S is offline
post #3 of 12 (permalink) Old Mar 18th, 05, 1:49 PM
The VIN should be on a Turbo 400 on the drivers side near the pan. There is a machined pad where the VIN will be. The VIN on both engine and trans should be the same font as they were stamped at the same time. On the left side of the transmission (passenger's side) there should be a metal tag, which will have the trans application code ie:CY and a julian date ie: 300. The rear will not have a VIN stamp on it, but will have the assembly plant and rear end codes on the front of the axle tube.
past assumptions aren't present realities...
greg2001 is offline
post #4 of 12 (permalink) Old Mar 18th, 05, 3:02 PM
'2' = Feb, '5' = 5th. Wheel made on 2/5/70
Tim
Team Chevelle #1877
'70 SS - L34/M20 (undergoing frame off)
70Z15 is offline
post #5 of 12 (permalink) Old Mar 18th, 05, 8:23 PM
Arlington started counting at 200001,not 100001.
mr70 is offline
post #6 of 12 (permalink) Old Mar 19th, 05, 7:42 AM Thread Starter
Nate
Thanks everyone for the info. Really appreciated! I'll post again when I get more numbers.
Mr70, based on what you wrote, that means our Chevelle was the 12,221st built at the Arlington plant, yes? Were there fewer Chevelles built there than other plants, or does that number sound about right for a car built the third week of February, 1970? Any idea?
TC #2423
post #7 of 12 (permalink) Old Mar 19th, 05, 8:27 AM
Arlington Tx. was a new plant for the Chevelle,begining production in December 1969.
It & FLINT were the plants that didn't produce as many units compared to other plants for 1970.
The last unit produced at Arlington in February 1970 was VIN#212783.
Your VIN falls in line with this as the 12,221st unit built.
mr70 is offline
post #8 of 12 (permalink) Old Mar 21st, 05, 8:51 AM Thread Starter
Nate
Thanks, Mr70. I'm amazed out how much info you have! If you don't mind my asking, how were you able to find out the VIN of the last car that rolled off the line at Arlington in Feb, '70?
Greg, I did a cursory glance at the car yesterday and grabbed what I could see on the trans. I couldn't see the pad with the VIN because of the recently installed 2.5" exhaust. I'll put it on a lift later and see if I can locate it. On the passenger side, I did find a metal tag with the following info (as best I could see):
C 73J 287 J
CJ 13110
The "C" & "J" on the first line were subdued print, i.e. not stamped letters.
Also, on the water pump:
C 2-70 GM 13969811 TX
The A/C compressor bracket:
3940948
Is there a number cast into the intake manifold as well?
No luck on finding anything on the rear-end, but I really need a lift to get a clear view for that as well. Thanks again, everyone.
TC #2423
post #9 of 12 (permalink) Old Mar 21st, 05, 3:01 PM
I have a collection of Chevrolet Zone letters/TSB/Service News & one of them lists the last VIN#'s built at each plant for each month,for each year.
Your Trans decodes as a 1973 420/240HP TRUCK TH400.
Assembled 287th day of 1973.
Serial #13110.
Water Pump is the correct # but dated March 2nd 1970.
I don't know what intake you have,but if it's cast iron,look for a part# behind the rear of carb,on the top facing up in front of Distributor.
If it's aluminum,it might be a #569 to the left of thermostat.
mr70 is offline
post #10 of 12 (permalink) Old Mar 21st, 05, 3:45 PM Thread Starter
Nate
Thanks again. I figured by the "73" on the trans and the Julian date that it wasn't original to the car and the previous owner had stated he didn't think it was original anyway. The engine was more important to us all in all.
Odd that the water pump is the wrong date. Is the "TX" any reference to the Arlington TX plant or just coincidence?
I'll check out the intake manifold. At least now I know where to look. Gotta love Bowties, tho -- the 428 in my Mustang is wedged in there so tight that changing spark plugs, much less looking up numbers, is damn near impossible. But on the Chevelle and the Monte I can crawl right up in the engine bay.
TC #2423
post #11 of 12 (permalink) Old Mar 21st, 05, 3:49 PM
The TX suffix is not referring to the State of Texas...merely a coincedence.
mr70 is offline
post #12 of 12 (permalink) Old Mar 21st, 05, 4:39 PM
Talking Re: '70 Chevelle Decode Please
Too cool ! Mine is a 4th week car , 155 units after yours & has the same build date & code for the engine ! Guess that makes us related !
chevelleshack is offline
This Thread is more than 5585 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
1972 Chevelle SS without Stripes Agugliel72SS Restoration Corner 5 May 27th, 06 6:29 PM
Chevelle Pros and Cons stc37 2004 4 Dec 2nd, 04 7:41 PM
Decode my part number please jtjohnston Restoration Corner 9 Nov 26th, 04 1:40 PM
chevelle sort of question mod malibu 2004 0 Oct 11th, 04 11:01 PM
70 Chevelle Rear Decode Help waynew Tag Team 2 Jan 3rd, 04 8:08 PM
