'68 Rear Axle Date Code Quandry? - Chevelle Tech
post #1 of 6 (permalink) Old Jul 12th, 15, 6:36 AM Thread Starter
Bruce
OK, so I picked up this '68 el Camino recently, very straight and solid car, mostly original, engine (L35 396/325) definitely casting and stamped numbers match up, but have a quandary about the rear.
COWL tag show car built 3rd week of December 1967 (12 C), rear is stamped "CW 0103 B" which is January 3rd, 3.31 open. Casting date is "L 5 7" which is December 5, 1967.
So could this be the original rear?
I have heard that it is possible due to the Christmas Holidays?
'68 el Camino SS 396/325hp, 4 Speed, 3.31, Buckets, AC
'75 el Camino SS, 400 SB, 200R4, 3.42 LSD, AC, Swivel Buckets, PW, PDL
'87 el Camino SS 305 TPI, 200R4, 3.73 LSD
'87 Buick Grand National (Hardtop, Bucket Seats)
PaceCarNut is offline
post #2 of 6 (permalink) Old Jul 12th, 15, 9:30 AM
6t8
Alex
Re: '68 Rear Axle Date Code Quandry?
Yes, I think so because the plant shut down for the holidays. Probably your vehicle sat on the Assembly line over Christmas Shutdown. (typically last two weeks of December) Kinda cool when you think about it, the body never left Fisher Body plant till the new year.
6t8 is offline
post #3 of 6 (permalink) Old Jul 12th, 15, 12:08 PM Thread Starter
Bruce
Here's where my disconnect with that is:
If the COWL tag says the car was built 3rd week of December, wouldn't the rear have to be under the frame at that point to put the body on during that week? If so, then how can the rear be stamped as being built that 2 weeks after the car build date?
post #4 of 6 (permalink) Old Jul 12th, 15, 2:51 PM
Randy
Not necessarily. Because of Christmas vacation shutdown, assembly plants don't empty the production lines. Everything stops in place and resumes when holiday is over. It's possible the cowl tag was applied to the body before the frame was 'married' to it, and also possible the axle had not yet been assembled to the frame.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #5 of 6 (permalink) Old Jul 12th, 15, 3:01 PM
Terry
If I recall correctly , the trim tag was applied to the body before it left FB plant. I could be wrong, if so someone more knowledgeable than me will chime in. Terry
68-13427 is offline
post #6 of 6 (permalink) Old Jul 13th, 15, 12:23 AM
Yes, I believe this is correct.
1969 Chevelle SS 396 4spd
1972 Chevelle SS 402 4spd #'s Matching!(SOLD 9-9-11!!)
1970 Monte Carlo SS 454
1969 Camaro RS 4spd
1970 442 4 speed
1970 F-85 W-31 4spd
1971 Monte owned since '86
69SS3964Spd is offline
This Thread is more than 1821 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
