70 code help - Chevelle Tech
post #1 of 3 (permalink) Old Nov 26th, 10, 8:59 PM Thread Starter
James
70 code help
We took possesion of this car when my Father-in-Law passed away a few years ago. I just need help with the numbers to see what it originally came with. I am working on the engine tag numbers, but have not found them as of yet. Anyway, here are the VIN and the cowl numbers. Thank you for the help.
VIN-136370R251180
Cowl - ST 70-13637
TR 771 55 A PNT
06A046
From what I can decifer it was built in Arlington and was bronze in color?
Meatdawg is offline
post #2 of 3 (permalink) Old Nov 26th, 10, 10:30 PM
Ethan
Re: 70 code help
VIN-136370R251180
Cowl - ST 70-13637
TR 771 55 A PNT
06A046
Welcome to TC, James!
1- Chevrolet
36- Malibu, 8 Cylinder
37- 2-Door Sport Coupe
0- 1970
R- Arlington, Texax (Assembly Plant)
251180- Sequential Production Number
Trim Tag:
70- 1970
13637- Malibu 2-Door Sport Coupe
771- Antique Medium Saddle Coated Fabric (Bucket Seats)
55 A- Champagne Gold w/ White Vinyl Top
06A- June, 1st Week (Build Date)
046- Data Processing Number (Found on block 10 of build sheet)
In order to find out what engine was originally in your car, is if you can find a build sheet, dealer invoice, POP, etc. to tell you exactly what engine came in it. If it is the original engine in your car, the partial VIN on the engine should match your VIN on the dash.
Look for the number's shown here on the engine:
Check out Dale's site for more information: http://chevellestuff.net/1970/index.htm
Good luck!
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #3 of 3 (permalink) Old Nov 26th, 10, 11:06 PM Thread Starter
James
Re: 70 code help
Thanks Ethan. I just found the build sheet about 10 minutes ago! It says it came with the 396. I will check the engine codes and go from there. The car is no longer Champagne Gold nor does it have a vinyl roof. It is Fathom Blue with white stripes and a hard roof. Hopefully the engine numbers match. Thanks again.
Meatdawg is offline
This Thread is more than 3507 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
