Which 396 did it have? - Chevelle Tech
post #1 of 9 (permalink) Old Nov 21st, 10, 6:20 PM Thread Starter
Larry
I'm new to this numbers stuff. Is there any way of telling which 396 (325 or 360) came in my car originally?
67 chevelle, 496/400/12bolt.
red/black int.
"Sure, I can make that slower for ya."
ACES member # 9266
Can-Am Chevelle member# 276
Team Chevelle member # 4917
R66SS427 is offline
post #2 of 9 (permalink) Old Nov 21st, 10, 6:48 PM
Keith
Re: Which 396 did it have?
nope. if your car has a original KK tach you can tell by the red line.
Maryland Chevelle Club #682
keithb is offline
post #3 of 9 (permalink) Old Nov 21st, 10, 6:50 PM
Was it made in US plant or Canada?
Dave Bradley
d1_bradley is offline
post #4 of 9 (permalink) Old Nov 21st, 10, 7:29 PM Thread Starter
Larry
Made in Atlanta. Knee knocker is long gone.
red/black int.
ACES member # 9266
R66SS427 is offline
post #5 of 9 (permalink) Old Nov 21st, 10, 8:02 PM
Todd
This info would be on the builtsheet or POP if you have any of the cars original documentation. If your car has its factory installed 396 you can check the suffex code and vin #'s on the engine pad.
Luke is offline
post #6 of 9 (permalink) Old Nov 21st, 10, 8:12 PM
Ethan
Yeah, a build sheet or the Protect-O-Plate would have the engine/code on it/them. Has the original interior been taken out? Everything still there? Try looking for a build sheet (if you don't have one).
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #7 of 9 (permalink) Old Nov 21st, 10, 9:34 PM
Dale
Unless it's a Fremont, CA-built Chevelle it won't have a conventional 'build sheet' as one thinks of a 69-72 style build sheet. You'd need to find a CHASSIS BROADCAST COPY sheet. This will have the engine suffix code on the third line of the sheet such as EH on this partial example from the Reference CD. Finding a CHASSIS BROADCAST COPY sheet is rather rare though - usually glued to the inner fender and destroyed over time.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #8 of 9 (permalink) Old Nov 21st, 10, 9:58 PM
Ethan
That is right, Dale. No build sheet, but the Chassis Broadcast Sheet copy. I had a brain fart.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #9 of 9 (permalink) Old Nov 21st, 10, 11:10 PM
Dale
I'm not sure "build sheet" or "buildsheet" is the proper name for the 69-72 paperwork we normally call a build sheet but I think the term is pretty universally accepted. Someone on here in a thread called it something like a "broadcast sheet" since ther are multiple copies that are broadcast to several sub assembly stations and often resulting in more than one copy being found in a car. Kind of like a "trim tag" or "firewall tag" is really a Fisher Body Number Plate.
* Author:
DaleM is offline
This Thread is more than 3386 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
