67 Cowl Tag Decode Help - Chevelle Tech
post #1 of 7 (permalink) Old Nov 12th, 10, 10:10 PM Thread Starter
I have just about all of this tag figured but am a little puzzled by a few of the numbers on the cowl. I have bolded what I am unclear on -- here's what I have:
General Motors Corporation
04D
ST 67-13617 BF15137 Body
TR 759 RR Paint
46202 020140
Body By Fisher
04D = ??December 4th?? - Not sure on this one
67-13617 = a 1967 Malibu 8 Cylinder, 2 Door Sport Coupe
BF = Fremont Plant
15137 = Production number
TR 759 = Interior - Black Rocina Cloth/Vinyl
46202 = ??????? Uncertain ????????
020140 = ????? Again - no idea ????
Thanks again for your wisdom!
carcia is offline
post #2 of 7 (permalink) Old Nov 12th, 10, 10:14 PM
Ethan
Re: 67 Cowl Tag Decode Help
04D
TR 759 RR Paint
46202 020140
Body By Fisher
BF = Fremont Plant
04D- April, 4th Week (Build Date)
46202- Order number from dealer order sheet
020140- Probably an Identification number found on Trim & Body Broadcast Sheets
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #3 of 7 (permalink) Old Nov 12th, 10, 10:17 PM
Ethan
Also, the 15137 is not a production number, but a Fisher Body Unit Number.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #4 of 7 (permalink) Old Nov 12th, 10, 10:23 PM Thread Starter
Thanks Ethan.
Forgot to mention the Paint RR which is obviously Bolero Red.
Appreciate the help. Just trying to learn as much as I can about my ride. It's come a long way in the few years that I've owned it!
carcia is offline
post #5 of 7 (permalink) Old Nov 12th, 10, 10:28 PM
Ethan
Thanks Ethan.
Sounds like you have a nice Chevelle.
BTW, '67 Chevelle's are my second favorite model year.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #6 of 7 (permalink) Old Nov 13th, 10, 12:36 PM
Send a message via AIM to FlameOut
This could also be a 6 cyl engine. If your check your VIN and it is 135, it came with a 6 cyl, if it's 136, it came with a V8, (if it's 138, it's a 396 - but itwould also show 138 on the cowl tag if that were the case)
396 (402) .030" over
Edelbrock
Performer RPM Air Gap
Lunati 60203 / KB 0.180
domed pistons
Holley Street Avenger 770
Muncie M-22
12 bolt posi 3.31
FlameOut is offline
post #7 of 7 (permalink) Old Nov 13th, 10, 7:17 PM Thread Starter
VIN is a 13617 so looks like it came with an 8 cyl - probably a 283. When I purchased the car it had a '77 454 with a '68 Saginaw 4 speed. Now has a period correct fresh 396 with '67 Muncie .
Removed the original column which was a three on the tree and replaced with a rebuilt '67 SS column.
carcia is offline
This Thread is more than 3523 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
