67 trim tag numbers - Chevelle Tech
post #1 of 9 (permalink) Old Oct 25th, 10, 6:11 PM Thread Starter
67 trim tag numbers
I've got my trim tag decoded with exception of the numbers on the bottom of the tag, can't find info. Anyone know?
CO8
32940 170254
Raffman is offline
post #2 of 9 (permalink) Old Oct 25th, 10, 6:58 PM
Ethan
Re: 67 trim tag numbers
CO8
32940 170254
C08- Vinyl Top
32940- Order Number from Dealer Order Sheet
170254- Identification Number found on Trim & Body Broadcast Sheets
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #3 of 9 (permalink) Old Oct 25th, 10, 8:03 PM Thread Starter
Thanks, the paint code is C2, I thought that meant white with black vinyl top .
Raffman is offline
post #4 of 9 (permalink) Old Oct 25th, 10, 8:16 PM
Mike Crown
It does mean White with Black Vinyl Top.
C08 is an Option Code for Vinyl Top.. not color specific.. usually found on FREMONT Assembly Plant Cars.. but not always..
The other numbers on TRIM Tag are internal Plant Tracking and Job Numbers... They are not option codes and as I always say.. tell you nothing specific about YOUR car.
66 MYSTERY CHEVELLE is offline
post #5 of 9 (permalink) Old Oct 26th, 10, 8:25 AM Thread Starter
Mike how can I get a copy of the fact cd? I tried the links and email but something about a default not installed,??
Raffman is offline
post #6 of 9 (permalink) Old Oct 26th, 10, 9:41 AM
Dale
As Mike noted the C08 was used only on Fremont Chevelles in 67. Can't say whether it was on all vinyl topped Chevelles but I have photos of Fremont tags from October or 66 through July of 67 and every one with a vinyl top has the C08 code on the tag. FWIW, Fremont did this in 66 as well and was the only U.S. plant to include the C08 code onthe trim tag.
One area I kind of/sort of have a different take is the dealer order number and Body Broadcast Sheet number found on Fremont Chevelles. The number itself won't tell you anything about the car but if you are lucky enough to find either with the car, you can verify it is for that car by these numbers.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #7 of 9 (permalink) Old Oct 26th, 10, 11:56 AM Thread Starter
Here's my info, my question is how close to the end run of chevelles in fremont was it/
07c
st 67-13617 BF22370
tr 750 C2
co8
32940 170254
Raffman is offline
post #8 of 9 (permalink) Old Oct 26th, 10, 1:48 PM
Dale
07c
st 67-13617 BF22370
tr 750 C2
co8
32940 170254
Have to know the sequence number for that. The last GM reported sequence for Fremont in 67 was 161500 although I've seen a 162028 sequence for Fremont. The last confirmed trim tag and matching VIN is 07B, sequence 159910 so this should, obviously, be higher than the 159910.
* Author:
DaleM is offline
post #9 of 9 (permalink) Old Oct 26th, 10, 2:45 PM Thread Starter
I'm 07C 1602xx not the end run but pretty close.
Raffman is offline
This Thread is more than 3275 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
