engine casting #'s - Chevelle Tech
post #1 of 11 (permalink) Old Oct 20th, 10, 5:25 PM Thread Starter
Larry
engine casting #'s
OK, first, I'm no pc geek. I tried to search but can't seem to find what I need. Can somebody tell me the block casting # for a 66 396/375? Going to look at a car friday and want some facts to go by.
Thank you!!!
67 chevelle, 496/400/12bolt.
red/black int.
"Sure, I can make that slower for ya."
ACES member # 9266
Can-Am Chevelle member# 276
Team Chevelle member # 4917
R66SS427 is offline
post #2 of 11 (permalink) Old Oct 20th, 10, 5:39 PM
Ethan
Re: engine casting #'s
I believe it would be 3855962. I'm pretty sure that is it.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #3 of 11 (permalink) Old Oct 20th, 10, 5:45 PM
& Administrator
If your trying to validate originality ,you'll want more than just the block casting number.
Get what you can that's shown in the pic
Casting date and engine id are great to tell if this is the engine the vehicle was born with.
Here's the 66 Chevelle BBC engine id codes
ED 66 396 Chevelle 325 L-35 4-Spd 4-Brl
EF 66 396 Chevelle 360 L-34 4-Spd 4-Brl
EG 66 396 Chevelle 375 L-78 4-Spd 4-Brl
EH 66 396 Chevelle 325 L-35 4-Spd 4-Brl
EJ 66 396 Chevelle 360 L-34 4-Spd 4-Brl Holley, A.I.R.
EK 66 396 Chevelle 325 L-35 Power Glide 4-Brl Holley
EL 66 396 Chevelle 360 L-34 Power Glide 4-Brl Holley
EM 66 396 Chevelle 325 L-35 Power Glide 4-Brl A.I.R.
EN 66 396 Chevelle 360 L-34 Power Glide 4-Brl Holley, A.I.R.
Block should be the 962 as posted but if it's not a 375hp ,it should be the 961.
Mike is offline
post #4 of 11 (permalink) Old Oct 20th, 10, 5:49 PM
Usually... I think there were some 961 4-bolt blocks, as well as perhaps some late 406 blocks, depending on the cars build date...
Some 360 HP came with 4-bolt blocks (#962s too)
Not fool proof, but fairly reliable to look for the large oil fittings above the oil filter (2 bolt blocks usually only had one fitting, while 4-bolt blocks usually had two LARGE fittings). 375 HP will use the 4-bolt. Some 360 HP also used the 4-bolt blocks.
Heads should be 858s, intake 069... Pulleys should be deep grooved, with a cast-iron crank pulley.
Check the sticky in the "restoration" forum, and it will tell you what the proper radiator should be.
TC #1366
Sold
Sold
1966_L78 is offline
post #5 of 11 (permalink) Old Oct 20th, 10, 6:00 PM
Bruce
"Can somebody tell me the block casting # for a 66 396/375? "
Tony is correct, 961 4-bolt used at end of year (approx. late May through July) with the possiblity of 406 4-bolt at the very end. Otherwise, a 962 4-bolt.
66 El Camino 396/325HP 4-Spd
My Build Thread:
62 Corvette 327/360HP (original RF engine and Fuel Injection) (future restoration project)
66 Corvair My son's project. Small block, Powerglide, C5 differential and rear suspension
72 Chevelle wagon project
AZCamino is offline
post #6 of 11 (permalink) Old Oct 20th, 10, 6:10 PM
& Administrator
Additional info so you don't need to look too far
http://chevellestuff.net/1966/index.htm
Dale's site has codes and how to interpret the VIN and cowl tag's.
Sorry Dean ,it's just easier on the poster if I just link it
Mike is offline
post #7 of 11 (permalink) Old Oct 21st, 10, 3:07 AM Thread Starter
Larry
Thanks guys. Trim tag says built 5th week oct. which I guess is good. Heard 375 was a late option in 66?
red/black int.
ACES member # 9266
R66SS427 is offline
post #8 of 11 (permalink) Old Oct 21st, 10, 7:49 AM
That would be the 5th wk of Oct 1965! Which would be early in the model year. Model years ran August to July of following year*, * which is the model year.
In Oct of 1966 they would have already been building 1967 models for 2 months.
elcamino is offline
post #9 of 11 (permalink) Old Oct 21st, 10, 1:20 PM
Bryon
375 hp was an option late in the 67 model year, not 66. Available all year from what I know in 66.
Red 1967 Chevelle SS 396, 4 speed, 3.31 12 bolt posi, black bench seat interior, Bolero Red - long term restoration project
68 Camaro SS - 468 BBC, 781 heads, RPM Air Gap intake, Lakewood bellhousing, M21, BO coded 12 bolt - but 3.31 posi now. Old drag car, back on the street.
bcmiller is offline
post #10 of 11 (permalink) Old Oct 21st, 10, 5:29 PM Thread Starter
Larry
Yup. You're right.
red/black int.
ACES member # 9266
R66SS427 is offline
post #11 of 11 (permalink) Old Oct 23rd, 10, 1:16 PM Thread Starter
Larry
Well, the guy was a fraud. Said he had XXXthousands in receipts but "oh dard, he forgot them". Car was nothing like the add. He was just trying to steal a high dollar car in trade for his junk. Needles to say, I didn't bite. Thanks anyway guys.
red/black int.
ACES member # 9266
R66SS427 is offline
This Thread is more than 3280 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
