Engine block code help - Chevelle Tech
post #1 of 2 (permalink) Old Oct 20th, 10, 10:40 AM Thread Starter
Looking at a 1967 Malibu with a 327 and owner states it is original to the car. He tells me the engine block code is HC. Can this be correct? Thanks.
johnz2 is offline
post #2 of 2 (permalink) Old Oct 20th, 10, 11:38 AM
Dale
Re: Engine block code help
No. 1967 Chevelle 327 has suffix codes of EA, EB, EC, EE, EQ, ER, and ES. http://chevellestuff.net/1967/engine_id_codes.htm
An HC coded 327 is a 65, 67 or 68 passenger car; essentially the same 327/275 w/Powerglide but not original to the Chevelle. You'd need to get the casting number off the block and maybe the date as well to determine the year. Several 327 blocks used from 65 through 68.
http://chevellestuff.net/qd/block_casting_by_year.htm
As a side note, the 66 model year passenger car had the same engine but was coded HCH if it had a Holley or HCR if it had a Rochester.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
This Thread is more than 3412 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
