Please help id this engine code - Chevelle Tech
post #1 of 14 (permalink) Old Sep 29th, 10, 6:46 PM Thread Starter
Michael
I have a 1971 chevelle with matching vin and fisher tag, but I'm pretty sure the engine was replaced. I have no idea what's it is, nor what's inside. I followed the directions on here and after removing some paint, I was able to fing the engine id on the front passenger side of the block.
CBJ128281
Any ideas what this is? No spaces. Nothing else.
This is my first classic car. It was given to me by my father. I'm getting kind of excited about it but want to know what I'm starting with before taking it to a performance shop for some updating. If this engine is crap I may just head on to a CE.
Thanks.
man44a is offline
post #2 of 14 (permalink) Old Sep 29th, 10, 6:59 PM
Ethan
Re: Please help id this engine code
CBJ128281
Thanks.
Can you recheck that? All I can find is CBG. Which is a '71 350. Maybe get the casting date off the rear of the block. Usually looks like E161 or D250, etc.
Thanks,
Ethan
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #3 of 14 (permalink) Old Sep 29th, 10, 7:03 PM Thread Starter
Michael
Can I get the casting date without pulling the motor?
man44a is offline
post #4 of 14 (permalink) Old Sep 29th, 10, 7:05 PM
Ethan
Yes you can. Your just going to have to lean over the engine to get it. Flashlight would be handy, too.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #5 of 14 (permalink) Old Sep 29th, 10, 7:07 PM
& Administrator
Ethan ,that looks like a part VIN.
C = Chevrolet
B = 1981
J = Janesville
128281 = sequential build number
Mike is offline
post #6 of 14 (permalink) Old Sep 29th, 10, 7:10 PM
Ethan
C = Chevrolet
B = 1981
J = Janesville
Look on the front of the block above the timing chain cover for an engine code.
Thanks for correcting me, Mike. That is what I thought it was at first, but thought the CBJ could have been the end of the suffix code.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #7 of 14 (permalink) Old Sep 29th, 10, 7:12 PM
& Administrator
note the edit.
Mike is offline
post #8 of 14 (permalink) Old Sep 29th, 10, 7:49 PM Thread Starter
Michael
Here's pics of all I could find. In case they dont upload, please see below.
In front middle of block: T1218TRL
In Back:
GMT1
486839
D 8 82
Hard to read.
ID:	34785   Click image for larger version
man44a is offline
post #9 of 14 (permalink) Old Sep 29th, 10, 10:08 PM
& Administrator
Where'd you go Ethan?
TRL 81 454 Truck 210 LE-8 Manual 4-Brl C-20 & C-30, A.I.R.
Mike is offline
post #10 of 14 (permalink) Old Sep 29th, 10, 11:10 PM
Ethan
Mike,
There were a lot of TRL's (small block & big block) and couldn't tell which one it was. Glad your here or I would be screwed. Your "THE MAN" when it comes to this stuff. I'm trying to learn though.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #11 of 14 (permalink) Old Sep 29th, 10, 11:20 PM Thread Starter
Michael
Im new to this and I know this is the wrong section of the forums, but what is the potential of this engine? Is it worth keeping and adding performance upgrades, or would it be cheaper to just get a vortecpro CE?
Thanks for helping ID this thing.
man44a is offline
post #12 of 14 (permalink) Old Sep 29th, 10, 11:26 PM
& Administrator
Yeah it's worth keeping.
Being from a C20/30 it's likely a 4 bolt block.
Let the shop open it up and see what/if it needs anything.
Raise the compression and add a cam and you up close to 500hp with the other usual components.
Carb,manifold,headers.etc.
Mike is offline
post #13 of 14 (permalink) Old Sep 29th, 10, 11:52 PM
Ethan
I would keep it as well. Build up from it.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #14 of 14 (permalink) Old Sep 30th, 10, 7:39 AM
C = Chevrolet
the C denotes the Chevrolet Truck Division, a 1 in this position would denote a Chevrolet car.
Note-Not all truck engines were 4-bolt main, only way to definitively know if to remove the pan. 1/2 and 3/4 ton trucks were not necessarily considered HD trucks so a 2 bolt was common in a lot in them.
elcamino is offline
This Thread is more than 3404 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
