SBC Block ID - Chevelle Tech
post #1 of 5 (permalink) Old Sep 29th, 10, 1:01 PM Thread Starter
SBC Block ID
I'm trying to decide if this short block is worth keeping around. Casting numbers at the back are 3903352 with a date of E 8 7 . It also has T4 on the other side of the bell housing flange.
Stamped numbers at the front are TO5I(1?)5KL. Also **177959 & 352948 &
T
G 12
A
For some reason I believe it might come from a full size car, but am not sure. Is this a small journal block? And if it is, does that mean anything significant? Thanx
ACES #00140
TEAM CHEVELLE #0038
Last edited by rick; Sep 29th, 10 at 1:03 PM. Reason: Proper orientation of the T G 12 A
rick is offline
post #2 of 5 (permalink) Old Sep 29th, 10, 1:13 PM
& Administrator
Re: SBC Block ID
3903352 = 67 327 ,210-350hp ,2-bolt ,small journal.
KL = 67 327 Impala 275 L-30 T-H 400 4-Brl Hyd Cam
Stamping would be T0515KL ,for Tonawanda assembly on May 15 ,1967
Mike is offline
post #3 of 5 (permalink) Old Sep 29th, 10, 1:37 PM
Ethan
Re: SBC Block ID
The date code on the block I believe is May 8, 1967 as well.
So as Mike noted, 1967 Impala 327/275hp engine.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #4 of 5 (permalink) Old Sep 29th, 10, 2:42 PM Thread Starter
Re: SBC Block ID
Thank you both, sounds like I ought to be looking for a good home for it.
ACES #00140
TEAM CHEVELLE #0038
rick is offline
post #5 of 5 (permalink) Old Oct 3rd, 10, 9:45 PM
Warren
Send a message via AIM to tar6569
Re: SBC Block ID
Rick, can you send me a picture of the engine pad? I've never seen a 67 327 block from a fullsize car with the vin stamped on it. Would be a helpful reference shot for my research.
When you put the **, could you not read those 2 characters?
Thanks, Warren
1964-70 fullsize chevrolet research
tar6569 is offline
This Thread is more than 3426 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
