'69 Build sheet? - Chevelle Tech
post #1 of 10 (permalink) Old Sep 19th, 10, 10:58 AM Thread Starter
Troy
'69 Build sheet?
What are the chances of finding a build sheet in a '69 Atlanta built car? Most Atlanta built '70s had them glued to the back of the door panel but my understanding is '69 build sheets are much more uncommon. Is That correct? Thanks
blacknblue is offline
post #2 of 10 (permalink) Old Sep 19th, 10, 1:44 PM
Ethan
Re: '69 Build sheet?
I'm thinking Atlanta built '69s build sheets can be found. Inside door panels or in the seat springs are probably the most common area.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #3 of 10 (permalink) Old Sep 19th, 10, 1:48 PM
Troy,
You pretty much nailed it. Very few `69 buildsheets are found. Some are from the Framingham plant and then it's usually just a 1/3rd sheet.
Most seem to be from Baltimore, then Fremont and Leeds. Leeds cars tend to have Broadcast sheets on the inside of the front fenders, if the mice haven't gotten to them.
69 Chevelle SS396 L78 4-speed, Post Sedan, Black W/black vinyl bench seat. (Under restoration)
69 Chevelle SS396 L78 4-speed Post Sedan, Silver, black vinyl bench seat. Berger car
70 Chevelle SS454 LS6, M22, 4.10, Forest Green, Green buckets. (Nearing completion)
69 Chevelle SS 396 L35 Post Sedan, Silver, Blue bench, 4-spd (Sold)
RixLS6 is offline
post #4 of 10 (permalink) Old Sep 20th, 10, 9:51 AM Thread Starter
Troy
Thanks for the info guys. I stumbled across a '69 L78 car and although it does have it's original engine and rear axle I was hoping the build sheet might be found. Doesn't sound promising.
post #5 of 10 (permalink) Old Sep 20th, 10, 10:01 AM
Any pics of what you stumbled on?
RixLS6 is offline
post #6 of 10 (permalink) Old Sep 21st, 10, 9:07 AM Thread Starter
Troy
I didn't have a camera with me and no cell phone so no pictures yet.
post #7 of 10 (permalink) Old Sep 21st, 10, 9:48 AM
69 Build sheets have been found almost any where all over the car but some places such as in the seats are more common
joe58 is offline
post #8 of 10 (permalink) Old Sep 22nd, 10, 9:07 AM
My 69 Atlanta built had the broadcast sheet in the rear seat springs.
Nothing anywhere else. Checked inside the fenders, over the tank, inside door panels, behind front seats, even under the sound pad below the carpets..........pretty confident there is not one in.
bobm396 is offline
post #9 of 10 (permalink) Old Sep 22nd, 10, 1:20 PM Thread Starter
Troy
Bob, Was it a "build sheet" or a punch card that showed the model and interior trim option? Thanks, Troy
post #10 of 10 (permalink) Old Sep 23rd, 10, 5:49 PM
Troy
Not build sheet.
Not sure about "punch card"
Looks more like a "broadcast sheet"
Has: SEQ M DAY STYLE PLTOPT/6 BODY TRIM LWR TOP/ UPPER P/P
75 1 21 13637 AT 196413 756 67 B 4
1 2 3 4 5 6 7 8 9 10
Z?3 u57 B96 C08
More Boxes and more ##s
Hope this helps Bob
bobm396 is offline
This Thread is more than 3445 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
