engine decode - Chevelle Tech
post #1 of 15 (permalink) Old Sep 18th, 10, 7:57 PM Thread Starter
Anthony
engine decode
these were all the codes i found on the engine:
T14
E1176
361959P
SS1971 is offline
post #2 of 15 (permalink) Old Sep 18th, 10, 8:07 PM
Re: engine decode
361959 - 454 -73-85 - Car & Truck
SCOTT
TC #3238
ACES #7490
To secure these rights, Governments are instituted among Men, deriving their just powers from the consent of the governed, That whenever any Form of Government becomes destructive of these ends, it is the Right of the People to alter or to abolish it, and to institute new Government
The Declaration of Independence
furball8994 is offline
post #3 of 15 (permalink) Old Sep 18th, 10, 8:24 PM
Ethan
Re: engine decode
What I found as well.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #4 of 15 (permalink) Old Sep 18th, 10, 8:52 PM
& Administrator
Re: engine decode
See which code matches the stamping on the front pad -top right in pic:
CXX 76 454 Impala 225 LS-4 TH-400 4-Brl
CXY 76 454 Impala 225 LS-4 TH-400 4-Brl
TRZ 76 454 Truck 250 LF-8 Manual 4-Brl C-20 & C-30
TSA 76 454 Truck 250 LF-8 Manual 4-Brl C-20 & C-30
TSL 76 454 Truck 250 LF-8 Manual 4-Brl
Mike is offline
post #5 of 15 (permalink) Old Sep 18th, 10, 11:05 PM Thread Starter
Anthony
Re: engine decode
that code was 16J331402
SS1971 is offline
post #6 of 15 (permalink) Old Sep 18th, 10, 11:18 PM
& Administrator
Re: engine decode
Front of the block just above the timing chain cover?
Mike is offline
post #7 of 15 (permalink) Old Sep 18th, 10, 11:56 PM Thread Starter
Anthony
Re: engine decode
i believe so
SS1971 is offline
post #8 of 15 (permalink) Old Sep 19th, 10, 12:11 AM
& Administrator
Re: engine decode
UM ,NO ,I meant look there for the engine id code.
You first looked where B is now look where C is in the pic.
Mike is offline
post #9 of 15 (permalink) Old Sep 19th, 10, 12:35 AM
Ethan
Re: engine decode
That's the partial VIN, I believe. Which decodes to a 1976 Chevy engine built in Janesville. The code Mike is referring to is a 3 letter code.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #10 of 15 (permalink) Old Sep 19th, 10, 1:11 AM
& Administrator
Re: engine decode
It's still going to be one of the codes I posted earlier ,just thought he'd want to know just what it came from.
Um Ethan ,that would be a vehicle built in Janesville.
Engine's likely from Tonawanda.
Mike is offline
post #11 of 15 (permalink) Old Sep 19th, 10, 11:03 AM
Ethan
Re: engine decode
Oops, my mistake.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #12 of 15 (permalink) Old Sep 19th, 10, 12:39 PM
& Administrator
Re: engine decode
I know what you meant just didn't want to confuse the OP.
Mike is offline
post #13 of 15 (permalink) Old Sep 19th, 10, 5:27 PM Thread Starter
Anthony
Re: engine decode
ok that code was T05-CXY
edit: ok cool its the impala engine. but i got a set of 67 396/427 hypo heads on them, lots better than the garbage heads that were on there
SS1971 is offline
post #14 of 15 (permalink) Old Sep 19th, 10, 6:00 PM
& Administrator
Re: engine decode
You did check piston to chamber fitment -didn't you?
Closed chamber heads on open chamber pistons can cause interference issues.
What's the casting number of the heads?
Or do you have flat top pistons?
Mike is offline
post #15 of 15 (permalink) Old Sep 19th, 10, 6:11 PM Thread Starter
Anthony
Re: engine decode
the heads fit fine, they were already installed on the engine when i got it. the casting numbers on the heads were like a 3904 code or something thats all i can remember from it
SS1971 is offline
This Thread is more than 3415 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
