Engine decoding for an outsider...CRV in a 72 C10 truck - Chevelle Tech
post #1 of 11 (permalink) Old Sep 12th, 10, 9:51 PM Thread Starter
Derek
Last week I purchased a 72 Chevy C10 PU that was advertised to have a "Corvette crate engine L88 454" in it. As far as I can tell, the L88 was only a 427, but that's beside the point. When I pulled the engine code from the front of the block and looked it up, it appears as though my engine is from a 70 Chevelle, and I was just wondering if I can get some more info from the people on this forum about what exactly I have. The numbers are T0114CRV and 10R214919. Also, the intake manifold number is 3963569 with the W snowflake.
Any and all info is appreciated...thanks in advance!
shiner2001 is offline
post #2 of 11 (permalink) Old Sep 12th, 10, 10:45 PM
& Administrator
Re: Engine decoding for an outsider...CRV in a 72 C10 truck
Welcome to TC.
1970 LS-6 that was assembled in the Tonawanda engine plant on January 14 ,installed in a Chevelle built in Arlington,TX.
If it were a crate engine the code would be different from the CRV.
Front of the partial VIN shows:
1 = Chevrolet
0 = 1970
R = Arlington,TX
214919 = assembly sequence.
3963569 = 396/402/454 70-71 Holley Rectangular port Aluminum Low rise L-78/L-89/LS-6
W snowflake is Winters Foundry that cast the manifold.
Mike is offline
post #3 of 11 (permalink) Old Sep 13th, 10, 9:46 AM
The L88 was a 427 not a 454. The LS6 is a 450 HP engine. the L88 was rated at 430 HP (more like 500+). The LS6 has better street manners (hydraulic lifter cam rather rhan a solid) than a L88 so you're better off with that for a street driven truck.
I never make mistakes, but on occasion I present myself with an opportunity to get very creative.
animal69 is offline
post #4 of 11 (permalink) Old Sep 13th, 10, 3:37 PM
I'd say the moter is worth as much as the truck to some one doing an ls-6 car.
69 SS396
CRUZN69 is offline
post #5 of 11 (permalink) Old Sep 16th, 10, 7:18 AM
The LS6 had solid lifters - hence the no A/C option on LS6 cars. The LS5 had hydraulic lifters.
David
davewho1 is offline
post #6 of 11 (permalink) Old Sep 16th, 10, 10:43 PM Thread Starter
Derek
The truck that I got the engine is has AC, but I guess that was just transferred over from the original big block that it came with (400).
post #7 of 11 (permalink) Old Sep 16th, 10, 11:19 PM
I 'guess' so, since a 454 wasn't available in a C10. Anyway the Big Block for a '72 C-10 was a 402 (the VIN code would be "E" if that was the case). And, a CRV 454 was a ONE YEAR ONLY engine available ONLY in a '70 SS Chevelle. If you could find the owner of the car with the stamped VIN, the engine would be worth FAR more than the truck. Oh, and its NOT a "crate engine" it was delivered in a car.
Dave Bradley
d1_bradley is offline
post #8 of 11 (permalink) Old Sep 17th, 10, 8:51 AM
For those who might be wondering why Chevrolet did not have A/C on a LS6 or any other mechanical (solid) lifter (L78, Z28) engines. Reason was they turned too high an RPM and the A/C compressor was not designed to run at those rpm's.
elcamino is offline
post #9 of 11 (permalink) Old Sep 17th, 10, 10:07 AM Thread Starter
Derek
Should I run a larger pulley on my AC in that case? Or I wonder if a new compressor would handle it alright...
post #10 of 11 (permalink) Old Sep 17th, 10, 11:16 AM
Doug
I wouldn't waste your money,just don't crank it to 6k+ with the ac on.
70 SS 454 LS-5 M-22 Bornwith Drivetrain-Sold New Baldwin Chevrolet
72 SS 454 El Camino W Code-427 4spd.
60',1.46, [email protected] [email protected]
Elky at Cecil
Chevelle Resto Pics
DougA is offline
post #11 of 11 (permalink) Old Sep 17th, 10, 11:20 AM Thread Starter
Derek
Yep, that makes sense too
Cart's ahead of the horse right now anyway, AC needs charging before I can use it in the first place.
This Thread is more than 3451 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
