Turbo-350 Codes? - Chevelle Tech
post #1 of 5 (permalink) Old May 13th, 10, 4:43 PM Thread Starter
Levi
Turbo-350 Codes?
found 2 sets of codes stamped in the bellhousing
21310 12508
13k434769
anyone have any idea what this may have come out of? it was in my 71 chevelle that has been a driver for many years.
1970 SS (cant prove it though) 427 4-speed
1971 Clone, 350 daily driver.
1970SS427 is offline
post #2 of 5 (permalink) Old May 13th, 10, 4:54 PM
Dale
Re: Turbo-350 Codes?
21310 12508
13k434769
The first two pair are probably dates and/or transmission serial numbers. The third character set looks like a partial VIN...
1 - Chevrolet
3 - 1973
K - Kansas City
434769 - sequence number, Chevelles began with 400001 in 1973 at KC.
According to http://www.novaresource.org/trans.htm, TH350 transmission codes are found...
TH350 (1972 and earlier)= on the upper flange of the transmission housing converter opening
TH350 (1973 and later) = on the right vertical surface of the oil pan
...but you said these are found on the bellhousing flange. Could be the resource above isn't 100% correct. Colvin's also says the TH350 in 1973 had the code on the transmission oil pan flange, passenger side.
Would you have a photo of it by chance or is up in the car where you can't really get to it?
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #3 of 5 (permalink) Old May 13th, 10, 4:58 PM
& Administrator
Also look on the accumulator cover on the passenger side of the trans.
Mike is offline
post #4 of 5 (permalink) Old May 13th, 10, 11:19 PM Thread Starter
Levi
i will try to get a picture of it tomorrow, it is out of the car and completely disassembled right now.
post #5 of 5 (permalink) Old May 14th, 10, 9:30 AM Thread Starter
Levi
I will get a picture once i get home from work this afternoon, however the codes i found are on the torque converter opening flange, although i dont remember which side right off the top of my head.
This Thread is more than 3670 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
