Is this a 70 Mirror? - Chevelle Tech
post #1 of 4 (permalink) Old May 4th, 10, 11:39 AM Thread Starter
Luis
3965923 BC
Thanks in advance
Luis
Canadian 70 SS Perfectly Documented
Luis is offline
post #2 of 4 (permalink) Old May 4th, 10, 12:09 PM
Re: Is this a 70 Mirror?
Luis,
Is that a number cast into the underside of the base, or a part number on the box?
They would be 2 different numbers depending on if it's for the casting, or the actual part number.
The part number would be 3914753 for the standard left, outside rear view mirror.
69 Chevelle SS396 L78 4-speed, Post Sedan, Black W/black vinyl bench seat. (Under restoration)
69 Chevelle SS396 L78 4-speed Post Sedan, Silver, black vinyl bench seat. Berger car
70 Chevelle SS454 LS6, M22, 4.10, Forest Green, Green buckets. (Nearing completion)
69 Chevelle SS 396 L35 Post Sedan, Silver, Blue bench, 4-spd (Sold)
RixLS6 is offline
post #3 of 4 (permalink) Old May 4th, 10, 12:33 PM Thread Starter
Luis
This is a number on the base of the mirror itself. I do not have the box.
Luis is offline
post #4 of 4 (permalink) Old May 4th, 10, 12:41 PM
Ethan
Luis,
Check here and does it have the date still on the mirror? Or has it worn off?
Ethan
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
This Thread is more than 3680 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
