Saginaw Close Ratio 825 ID? - Chevelle Tech
post #1 of 9 (permalink) Old Jan 4th, 10, 1:10 PM Thread Starter
Kent
I need to order hedders but it states they WILL NOT WORK with the Saginaw close ratio 825 gear box. What does the 825 look like? How can I tell what I have, will get PICS if needed.
Kent
Kent
1969 Chevelle SS Resto-Mod
2002 Mag Red Corvette Vert
TC #5237
ktullos is offline
post #2 of 9 (permalink) Old Jan 4th, 10, 5:46 PM Thread Starter
Kent
Re: Saginaw Close Ratio 825 ID?
Here are the PICS
Kent
TC #5237
ktullos is offline
post #3 of 9 (permalink) Old Jan 4th, 10, 5:57 PM
& Administrator
2 letter ink code still on it?
Mike is offline
post #4 of 9 (permalink) Old Jan 4th, 10, 6:01 PM Thread Starter
Kent
More PICS
When I turned the coupler went aprx. 3.25 turnes lock to lock.
Kent
Kent
TC #5237
ktullos is offline
post #5 of 9 (permalink) Old Jan 6th, 10, 8:02 PM Thread Starter
Kent
Not sure what your asking but it has been sand blasted.
Kent
Kent
TC #5237
ktullos is offline
post #6 of 9 (permalink) Old Oct 14th, 10, 9:22 PM
Rocky
Kent,
I have the same numbers on my gearbox as you have. I also have the same problem that you have. I want to put ceramic headers on my 1970 454 chevelle and I am worried that they will not fit once I get them and trying to return them is a pain. I have done alot of research and no one seems to have the answer. If there is any 1970 chevelle owners with a 454 and these steering box numbers, please advise which headers you have.
Thanks,
Rockman.
Rockman is offline
post #7 of 9 (permalink) Old Oct 14th, 10, 9:32 PM
Ethan
Check out this thread:http://www.camaros.net/forums/showthread.php?p=1458028
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #8 of 9 (permalink) Old Oct 14th, 10, 9:35 PM
Ethan
And the box you have seems like it was used on several GM cars for quite a few years.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #9 of 9 (permalink) Old Nov 19th, 10, 8:56 PM
Rocky
Kent,
I have answers.
See post
add headers, less Horsepower?
Rockman
Rockman is offline
This Thread is more than 3380 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
