Block, Trans VIN match? - Page 3 - Chevelle Tech
post #31 of 43 (permalink) Old Aug 20th, 09, 11:28 PM
Bryon
Re: Block, Trans VIN match?
OK, I thought it looked a little odd. I have never seen one quite like that before.
Red 1967 Chevelle SS 396, 4 speed, 3.31 12 bolt posi, black bench seat interior, Bolero Red - long term restoration project
68 Camaro SS - 468 BBC, 781 heads, RPM Air Gap intake, Lakewood bellhousing, M21, BO coded 12 bolt - but 3.31 posi now. Old drag car, back on the street.
bcmiller is offline
post #32 of 43 (permalink) Old Aug 21st, 09, 11:21 PM Thread Starter
Pat
The assembly code does match up with the POP and is a nice clean stamp.
Name:	1967 chevelle M21 assembly stamp.jpg
36j1967 is offline
post #33 of 43 (permalink) Old Sep 15th, 09, 10:01 AM Thread Starter
Pat
Here is the assembly code from the axel tube with the KM 4.56:1 prefix and 1130 date that matches the POP.
Name:	1967 chevelle KM 1130 B.jpg
1967 Malibu L79 M21 4.56:1 G66
36j1967 is offline
post #34 of 43 (permalink) Old Sep 15th, 09, 11:10 AM
Bryon
Pat,
I went back and looked at all of the pictures of your car. NICE. My uncle bought a very very similar car when he got back from Vietnam. Same color. 327 with 4 speed. I don't remember if it was an L79 car (probably not) but it ran good.
I would not worry about the area on the transmission with the partial VIN stamp that looks a little odd. Maybe the casting mold just did not get completely filled, or whatever. That is probably the way it left the factory, since everything else looks normal.
Does anybody know about how many 1967 L79 Chevelles would have had the KM coded rear with 4.56 gears? Probably not very many.
bcmiller is offline
post #35 of 43 (permalink) Old Sep 15th, 09, 11:55 AM
Rich
There is no way to know, GM did not save such statistics. We know how my L79s, we know how many KM 12-bolts, we just don't know how many with the combination of both (or any other combination you can think of).
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #36 of 43 (permalink) Old Sep 15th, 09, 1:12 PM
Bryon
Rich,
OK, how many KM 12 bolts? Probably a pretty low number?
bcmiller is offline
post #37 of 43 (permalink) Old Sep 15th, 09, 1:32 PM
Dale
I'm not sure figures are known on any 4.xx series rear ends. The Tailfins & Bowties documents I saw (where all reportedly GM option quantities sold are shown) do not list any 4.10, 4.56 or 4.88 gear options in 1967, or 64-68 for that matter).
There are specific numbers reported for 1969 but that seems to be the only year.
From 1970 thru 72, no specific ratios are shown but rather items like "YD1 Axle for Trailering" and "ZQ9 Rear Axle - Performance Ratio" but no specifics.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #38 of 43 (permalink) Old Sep 16th, 09, 9:50 AM
Bryon
Thanks Dale. I knew you would have an excellent answer.
bcmiller is offline
post #39 of 43 (permalink) Old Sep 16th, 09, 5:20 PM Thread Starter
Pat
This would have been a fairly complicated dealer order with the 4.56:1 gear ratio and might have required some Zone approval prior to being an accepted order. On other Chevrolet model orders prior to 1969 a performance drive train combination such as this would not have been included as a standard check off box on the dealer order paperwork. The owner of this car did some research on available GM RPO's and knew what they wanted and why they wanted it. I'd guess very few L79's or SS 396's Will be documented with 4.56:1 ratios. This combination would not work well except with L79's or L78's IMO.
36j1967 is offline
post #40 of 43 (permalink) Old Sep 17th, 09, 4:23 AM
What a neat and informative thread this is.
Nice car.
I may be old but I have seen all the great bands.
Bunz-T is offline
post #41 of 43 (permalink) Old Nov 26th, 10, 6:02 PM Thread Starter
Pat
I thought I'd update the progress on my car, she's in paint and the frame has been cleaned, detailed and painted and the short block is done...still standard bore! Most everything else is accounted for and the NOS trim and emblems are aquired and waiting for installation. I think we are over the hill and on the way back down on this project and hope to be under power in the Spring.
Name:	1967 chevelle straight 1.jpg
ID:	36291   Click image for larger version
Name:	67 chevelle paint hood.jpg
ID:	36292   Click image for larger version
Name:	67 Chevelle paint rear.jpg
36j1967 is offline
post #42 of 43 (permalink) Old Nov 26th, 10, 10:32 PM
Ethan
Love the color!
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #43 of 43 (permalink) Old Nov 27th, 10, 10:37 AM
Dale
Getting there
* Author:
DaleM is offline
This Thread is more than 3471 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
