Decode of 3973456n Flywheel - Chevelle Tech
post #1 of 5 (permalink) Old Dec 28th, 04, 9:25 AM Thread Starter
Post
Not having any luck on what this should fit? Date code is 73.
Specifically trying to figure out if it'll fit 396 internal balance with 11" clutch.
Thanks,
Flye is offline
post #2 of 5 (permalink) Old Dec 28th, 04, 1:21 PM
Post
I believe that a 396 is INTERNAL balanced. Some info I found on the net was that this crosses to GM p/n 3991469 and is for 67-85 all internal balanced engines with 11" clutch, 168 tooth ring gear with 2 pc rear seal. Should be obvious if its for 'external' balanced engine.
Dave Bradley
d1_bradley is offline
post #3 of 5 (permalink) Old Dec 28th, 04, 1:49 PM Thread Starter
Post
yes, 396 is internal. And that is what I was looking for, a flywheel that would fit the BBC, internal balance. Based on the above, it sounds like it would fit.
Now all I have to do is get that groove machined out of the face.....
Thanks.
Flye is offline
post #4 of 5 (permalink) Old Oct 7th, 10, 12:24 AM
RZO
Re: Decode of 3973456n Flywheel
Hello, I obtained a Flywheel 3973456 with a borg beck clutch. I have a 396 that I am converting back to a M21. In readinug your posts, you mentioned machining the grove out of the face? Can you let me know what has to be ground out, will it not fit the 396 as it is? Thanks
RZO is offline
post #5 of 5 (permalink) Old Oct 7th, 10, 11:53 AM
Ethan
Bob,
This post is 6 years old. I don't know if they are still on here. Might send them an e-mail. Or somebody else should know.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
This Thread is more than 3381 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
