Decoding resources - Chevelle Tech
post #1 of 5 (permalink) Old Apr 21st, 04, 10:52 AM Thread Starter
Rich
Post
There is a wealth of basic and detailed information available on VIN, trim/cowl tag, engine and axle codes that can be found at the following locations. Please consider consulting these databases before posting a question which could very likely be answered by the data found on these sites:
Team Chevelle Resources for year-specific information:
https://www.chevelles.com/years/index.shtml
Team Chevelle Resources for all kinds of Chevelle-related information:
Dale McIntosh's Chevelle Stuff:
http://www.chevellestuff.net/
One very useful page on Dale's site is for decoding Trim Tags:
http://chevellestuff.net/qd/tags/index.htm
How to spot a true 69-72 SS:
https://www.chevelles.com/shop/ss_ident.html
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #2 of 5 (permalink) Old Oct 10th, 04, 12:52 PM
post #3 of 5 (permalink) Old Mar 15th, 06, 5:28 PM
Re: Decoding resources
Steering column & steering gear information by Jim Shea
http://jimshea.corvettefaq.com/
A & F-car tilt column papers
Here are links to the A & F-car tilt column papers. All you ever wanted to know (and more) about replacing your tilt column rack. You can replace the rack with the column in the car but it is a real pain trying to adjust the ignition switch with the new rack. It is far easier to remove the column. Take off the capsule mounting bracket (the bracket where the two vertical fasteners pass through the aluminum capsules) that holds the column up into the dash. Tighten your vise on two of the bracket weld nuts that are in-line.
http://jimshea.corvettefaq.com/wp-co...lumnBlowup.doc
http://jimshea.corvettefaq.com/wp-co...ndr123ja06.doc
http://jimshea.corvettefaq.com/wp-co...D&R226JA04.doc
http://jimshea.corvettefaq.com/wp-co...ev28au2009.doc
http://jimshea.corvettefaq.com/wp-co...nLineDrwg1.doc
http://jimshea.corvettefaq.com/wp-co...nLineDrwg2.doc
http://jimshea.corvettefaq.com/wp-co...nLineDrwg3.doc
post #4 of 5 (permalink) Old Mar 15th, 06, 5:41 PM
Bruce
LOF and PPG glass codes.
http://www.camaros.org/glass.shtml
Bruce
66 El Camino 396/325HP 4-Spd
My Build Thread:
62 Corvette 327/360HP (original RF engine and Fuel Injection) (future restoration project)
66 Corvair My son's project. Small block, Powerglide, C5 differential and rear suspension
72 Chevelle wagon project
AZCamino is online now
post #5 of 5 (permalink) Old Oct 22nd, 08, 3:42 PM Thread Starter
Rich
This sticky thread is being locked. If you would like to offer other links which people may find useful, please send the moderator (me) a Private Message with the information.
Thanks.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
Closed Thread
This Thread is more than 4279 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
