'69 Chevelle transmission code XF - Chevelle Tech
post #1 of 3 (permalink) Old Dec 3rd, 07, 11:05 AM Thread Starter
The original build sheet on my Framingham built '69 Chevelle lists the transmission code in box number 28 as XF. What does this code out as? Thanks.
mandmwillman is offline
post #2 of 3 (permalink) Old Dec 3rd, 07, 1:16 PM
Dale
Re: '69 Chevelle transmission code XF
Can't say for Framingham but for other plants like Baltimore and Fremont it's listed on an L78 as M21 4 SPD CL RATIO. On a KC sheet though the same engine/trans has the trans coded as XD.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #3 of 3 (permalink) Old Dec 3rd, 07, 5:32 PM Thread Starter
Dale,
Thanks for the information. The car is an original L78, so it stands to reason. I appreciate your knowledge.
M.W.
This Thread is more than 4609 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
