Please help decode....T0921JW - Chevelle Tech
post #1 of 11 (permalink) Old Oct 29th, 07, 10:45 AM Thread Starter
Pat
My car has T09214W.....build sheet says "JW" could that be a typo???
TYZ TOYZ is offline
post #2 of 11 (permalink) Old Oct 29th, 07, 12:37 PM
Re: Please help decode....T0921JW
The Tonawanda stamp will read T0921XX
T=Tonawanda
0921= Sept. 21st.
XX= 2 Letter Suffix for Engine Code 2 Letters prior to Late 69.
I don't have my referance book to decipher JW, But JK was my 69 325HP.
Re-read you VIN pad on the Engine. Your "4" is in error.
Happy motoring!
69396ss is offline
post #3 of 11 (permalink) Old Oct 29th, 07, 1:30 PM
I'm assuming this is your VIN stamp. Whomever was working the line that day must have been hung over. The "4" is likely just an error on the stampers part. JW is likely your correct Suffix. They really screwed up the VIN too. It's so bad, it has to be genuine.
Happy motoring!
69396ss is offline
post #4 of 11 (permalink) Old Oct 29th, 07, 2:24 PM
James
I'm almost positive the 4W is correct. 4W decodes as 1968 4W Chevelle 396 350 Auto Trans . I would bet the GM of Canada paperwork has is wrong.
James
1968 Beaumont SD396
1968 El Camino
ACES #7986
jfkheat is offline
post #5 of 11 (permalink) Old Oct 29th, 07, 2:28 PM
Really, never noticed a Digit/Numeral Suffix.
Happy motoring!
69396ss is offline
post #6 of 11 (permalink) Old Oct 29th, 07, 3:14 PM
James
I hadn't seen that code either until TOYZ posted it here a couple weeks ago. Most codes that start with a number are marine engines. There are 3 cases where it was used for 1968 Chevelle 396s: 4T, 4U and 4W. Check the site below.
James
http://www.minuit10.net/EngineCode/chevy/0FC-9XZ.htm
1968 Beaumont SD396
1968 El Camino
ACES #7986
jfkheat is offline
post #7 of 11 (permalink) Old Oct 29th, 07, 8:04 PM
Ron
Thats right, all GM employees were drunks and any mistakes were because they were drunk or hungover
70 Chevelle SS396 (496) Straub roller, 700r4
69 Malibu convertible (sold)
TC #54 Gold
ToocoolZ28 is offline
post #8 of 11 (permalink) Old Oct 30th, 07, 9:40 AM
rob
My grandfather worked the GM line from the early 50's to the late 80's. He was not a drunk and is a good decent man. Your statement is offensive and narrow.
Rob
69badboy is offline
post #9 of 11 (permalink) Old Oct 30th, 07, 9:49 AM
Ron
I guess its hard to type in the sarcasm. Look at my quote, I was responding to HIS comment about the employee being hung over. I was a GM employee for 30 years and I am NOT A DRUNK either, but a lot guys think that EVERYONE that worked for GM was/is a drunk
TC #54 Gold
post #10 of 11 (permalink) Old Oct 30th, 07, 10:02 AM
rob
Ok I get ya. Sorry. Peace. I've got a few questions about the stamping tool.
What did they look like? They didn't stamp the numbers individually did they? Was it a tool that you could set the numbers and stamp the number in one hit?
Rob
69badboy is offline
post #11 of 11 (permalink) Old Oct 30th, 07, 10:26 AM
James
The stamp held several numbers and letters so it could all be stapmed at the same time. The first group was stamped at the engine plant and the second group was stamped at the auto assembly plant.
James
1968 Beaumont SD396
1968 El Camino
ACES #7986
jfkheat is offline
This Thread is more than 4633 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
