bought a 2- wire tach please help - Chevelle Tech
post #1 of 9 (permalink) Old Oct 20th, 07, 8:38 PM Thread Starter
dan
I bought a 2-wire tach at the swap meet tried installing it on my 71 chevelle today it looks realy nice but cant get it to work I ran 1-wire to the battery and one to the coil where it says tach than the car wouldnt start when I disconnected it the car started fine, someone told me there should be 3-wires im not sure it looks like it always had 2-wires am I doing somethin wrong?
prelude098 is offline
post #2 of 9 (permalink) Old Oct 20th, 07, 9:12 PM
Levon
Re: bought a 2- wire tach please help
1 wire to the coil (usually green) and 1 to ground.
What make/model is it? maybe the instructions are on the net???
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #3 of 9 (permalink) Old Oct 20th, 07, 9:31 PM Thread Starter
dan
I have an electronic ignition would this make a difference thanks 1-wire is red 1- is black
post #4 of 9 (permalink) Old Oct 20th, 07, 10:57 PM
Levon
Having an electronic ignition MAY affect the tach. What make/model is it?
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #5 of 9 (permalink) Old Oct 21st, 07, 3:05 PM Thread Starter
dan
the tach is a rotunda I really dont care if it affects the tach I just dont want to affect the electric ignition. If I hook it up is the wort case burning out the tack or making problems for the car? thanks
post #6 of 9 (permalink) Old Oct 21st, 07, 3:10 PM
Levon
These are old tach's that needed to be wired in series with the old points type ignition. They ran between the coil and the points on the negative side of the coil.
I don't think you are goingto get it to work with today's electric ignitions.
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #7 of 9 (permalink) Old Oct 22nd, 07, 7:00 PM Thread Starter
dan
thank you for your help I might try it I just hope I dont burn any thing out
post #8 of 9 (permalink) Old Oct 22nd, 07, 8:57 PM
Levon
Why take a chance if you do not know where to connect it. Burning out a module will cost you a lot more than an inexpensive tach that is guaranteed to work with your ignition.
Levon Hovagimian
Team Chevelle #279
LevonH is offline
post #9 of 9 (permalink) Old Oct 23rd, 07, 4:45 PM Thread Starter
dan
your right I am just pissed that I already have it mounted
This Thread is more than 4650 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
