Big Block Head Date Code - Chevelle Tech
post #1 of 2 (permalink) Old Sep 17th, 07, 8:31 PM Thread Starter
I was checking the casting numbers and date codes on the heads of my big block 70 Chevelle.
The one head had a casting number of 3964291 with a 1-10-78 date code.
Would it be correct to assume this is a replacement head?
I did not think any vehicles came with the rectangular intake ports in 1978.
The spark plugs are the larger 13/16" type.
Thanks!
DennyK is offline
post #2 of 2 (permalink) Old Sep 17th, 07, 9:07 PM
Levon
Re: Big Block Head Date Code
Looks like a replacement or over the counter head.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
This Thread is more than 4673 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
