Engine Decode - Chevelle Tech
post #1 of 5 (permalink) Old Sep 14th, 07, 11:26 PM Thread Starter
Ron
Engine Decode
3970010
V0508TYX
Chevy 350
Anybody know what motor this is. 2 or 4 bolt
70 SS 28/28 Fathom Blue, Pearl Stripes
Baltimore built, Build Date 0103
402 4 speed w/AC, M21, 3.31 w/build sheet.
Before -
After -
70chevelle.ss396 is offline
post #2 of 5 (permalink) Old Sep 15th, 07, 4:37 AM
Re: Engine Decode
I've got two of 'em with the same 3970010, one's a 4 bolt out of a '75 Chevy van, the other a 2 bolt out of a boat that also cross references to a '70 Caprice....you'll have to look at the other numbers to find year/model/combo. I can't remember where I looked before but you can't tell 2 or 4 bolt without pulling the oil pan. Mortec says '69-'80 model years.
1967 Chevelle Custom
SBC 383
Gear Vendors Overdrive
Jerico DR-4
S60, True Trac, 3.54 gears
cobaltchev67 is offline
post #3 of 5 (permalink) Old Sep 15th, 07, 11:21 AM
Re: Engine Decode
1978 TRUCK 350-165hp with TH350 trans, light duty 1/2
Likely not a 4 bolt but the pan has to come to know for sure..
elcamino is offline
post #4 of 5 (permalink) Old Sep 15th, 07, 1:35 PM Thread Starter
Ron
Re: Engine Decode
Thanks, the guy said he thought it came out of a 78 Blazer. These were hydraulic flat tappet cams, right?
Before -
After -
post #5 of 5 (permalink) Old Sep 17th, 07, 9:15 PM Thread Starter
Ron
Re: Engine Decode
Well pulled the pan and it is a 4 bolt.
I got the head numbers also.
333882 D245
333882 D255
The weird thing about the Pad numbers is that the second digit of VO508TYX is a square character. Like this []. Has anyone had this before? Also has a date code of E65. What is this date?
3970010 Casting
Front Pad
163237 V[]508TYX
Date
E65
Before -
After -
This Thread is more than 4675 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
