#'s and *'s on Build Sheets - Chevelle Tech
post #1 of 7 (permalink) Old Jun 19th, 07, 10:00 PM Thread Starter
Rich
Just wondering why certain RPO codes on my build sheet are preceded by a pound (#) sign and some codes are preceded by an asterisk (*).
Big White is offline
post #2 of 7 (permalink) Old Jun 19th, 07, 10:56 PM
mark
Re: #'s and *'s on Build Sheets
if you look in the lower right hand corner next to the option columns
on your build sheet it shows you . #body shop
%trim shop
*standard equip
why do only some of them have it, i dont know. but im sure someone here does
70 SS LS6
LIC #73
TC #3594
wannarun70 is online now
post #3 of 7 (permalink) Old Jun 20th, 07, 5:39 PM Thread Starter
Rich
Mark,
Thanks for your reply. I guess this falls under the category of Not Reading The Fine Print. As many times as I have scrutinized my broadcast sheet, I never noticed the tiny legend down in the r.h. corner.
As we both have observed, at first blush there doesn't seem to be any rhyme or reason as to why some options are preceded by these symbols and other options are not. Even more confusing is the fact that while both my vinyl top and console are preceded by a # (Body Shop), so is my transmission! Go figure.
At any rate, it would be interesting if someone has some knowledge that they can share with the rest of us.
post #4 of 7 (permalink) Old Jun 20th, 07, 7:37 PM
Dale
They aren't even consistent between cars from the same plant. A quick look at three sample Malibus from Baltimore shows two C56 I/P SIDE VENT with an equal sign (=) [body shop] and one with an asterisk (*) [standard]. Same items on KC sheets (both Malibu and El Camino) list it as C56 UPR LVL VENT with notations of = [body shop/trim shop]. Same item on Atlanta sheets are C56 I/P SIDE VENT with =* preceding.
The Baltimore sheets have # [body shop] preceding manual trans. applications where KC and Atlanta does not.
Just one of those things we'll probably never really know and something else that varied from plant to plant.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #5 of 7 (permalink) Old Jun 20th, 07, 8:50 PM
Warren
Send a message via AIM to tar6569
Yeah, the same for fullsize. With the *, the lower model cars won't have it on some things like malibus for example do. I know on fullsize cars, with the lighting groups for example, it was standard on impala so there is a * next to it but there is not one next to it on a belair sheet because it was optional. Most factories I have seen use the * but others do not use the # and %.
tar6569 is offline
post #6 of 7 (permalink) Old Jun 20th, 07, 9:10 PM
Chevelle Doctor
I can see the bodyshop symbol beside the trans option, because the 4 speed floor and an auto floor are different in the hump area for 70-72.
My Atl. LS5 sheet even has a ( beside the tire option. Figure THAT one out!
Authentication and pre-purchase inspection service still available. PM me for more information.
Still looking for that elusive 76 Nova SS.
People who have nothing better to do than b!tch about signatures need to get a life.
70 Chevelle L78/M21
10 Avalanche LT 1500 4wd
06 Equinox
Dave Birdwell is offline
post #7 of 7 (permalink) Old Jun 20th, 07, 11:51 PM
Dale
But, again, only on certain plants and apparently even then only sometimes with the # symbol on manual trans. None of my Atlanta sheets have anything beside the manual trans code and even the M40 is mixed, some with = and some without even when both have a console whether they're 396, 454, or even 350.
Is kinda strange about the ( before the tires though, I see that too.
* Author:
DaleM is offline
This Thread is more than 4772 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
