#'s Correct Radiator Verification - Chevelle Tech
post #1 of 7 (permalink) Old Sep 14th, 06, 9:29 AM Thread Starter
Smile #'s Correct Radiator Verification
Hi guy's,i need to know how i can correctly indentify a 3 or 4 core original HARRISON radiator for a 1969 ss 396 chevelle with man trans.
What are the correct pt#'s?
Where can the pt#'s be found,are they only on that little square metal tag thats usually gone on any radiator i have ever seen?
If the little metal tag is gone with the pt#'s what other indetifying things can i look for to tell me it's an original 1969 Harrison radiator.
Lastly,are there date codes stamped anywhere on the radiators and if yes where?
SCOTT
SWHEATON is offline
post #2 of 7 (permalink) Old Sep 14th, 06, 3:18 PM
Albert
Re: #'s Correct Radiator Verification
http://cgi.ebay.com/ebaymotors/1969-...mZ230019319153
IA and XJ are the tank codes..break down by years I think..codes are embossed on the tanks.
ALbert
1969 9566AA COPO Chevelle
1969 Malibu 489 ZL-1 T 56
1969 Beaumont 454 ZL-1 6 spd..under construction
1969 300 2 door post 427 ZL-1 4 spd
1970 Olds W 30 2 door post
MCC#511 ACES #1805
alss is offline
post #3 of 7 (permalink) Old Sep 16th, 06, 8:42 PM
Woj
Phil
I've got the info you need at home. If it is a low hp 396 with 4 speed, the correct two letter code is "BE". One of the tanks will be IA for sure, I'll have to check what the other is. Get back to you tomorrow.
Woj
Woj is offline
post #4 of 7 (permalink) Old Sep 16th, 06, 10:18 PM Thread Starter
Smile Re: #'s Correct Radiator Verification
Thanks for the info guys.
Woj,yes its both the 396/325hp & 350hp man trans 3 core & opt HD 4 core radiator id's i am interested in so please dbl check to verify those radiator id's,i really appreaciate it.
SCOTT
SWHEATON is offline
post #5 of 7 (permalink) Old Sep 17th, 06, 11:51 AM
Woj
Phil
Scott,
Albert is correct IA and XJ are the rad codes. BE is the tag code. Send me a pm with your email address and I'll send a picture.
Woj
Woj is offline
post #6 of 7 (permalink) Old Sep 17th, 06, 1:42 PM Thread Starter
WOJ,thanks a lot,i sent you my email adddress.
SCOTT
SWHEATON is offline
post #7 of 7 (permalink) Old Sep 17th, 06, 10:26 PM
Woj
Phil
Scott,
Pictures on the way.
Phil Woj.
Woj is offline
This Thread is more than 5049 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
correct tailpipe for 66 pur66msl Restoration Corner 18 Jan 13th, 06 3:50 PM
Correct carb/intake stud for 66 with Holley? Jim_66SS Restoration Corner 0 Dec 21st, 05 1:09 PM
Correct color of "Chevrolet Orange" on the motor 69396ss Restoration Corner 37 Dec 19th, 05 5:07 PM
MC which is the correct radiator hose for 66 BB? Jim_66SS Restoration Corner 0 Dec 3rd, 05 9:12 AM
what is the correct trunk mat for 65 bhawk Restoration Corner 2 Nov 28th, 05 10:22 PM
