Rear end #'s breakdown (70 Chevelle) - Chevelle Tech
post #1 of 4 (permalink) Old Jul 3rd, 06, 8:00 PM Thread Starter
Hi Guys,
I'm putting a "Casting numbers and datecodes sheet" together for my car, as I'm planning to have my car appraised. I thought this would be useful, so the guy doing the appraisal doesn't have to crawl all over my car looking for numbers.
Here are the numbers for my Differential # 3969278 NF 67890
GM51
On the right axle tube#CCF 0521B
Casting date: 0=1970 5=May 21=21st Day B=2nd Shift?
Build date for my car is 5/29/70
Does this look right for my car?
Thanks,
1970 Chevelle SS 396: (SOLD) but not forgotten!
New Ride 2013 Nickey Camaro Convt.800HP @ Crank Yeah baby!
Brian Henderson
A.C.E.S. #5637 T.C.#1932
450HPChevelle is offline
post #2 of 4 (permalink) Old Jul 3rd, 06, 8:04 PM
Andy
Re: Rear end #'s breakdown (70 Chevelle)
The dates appear to be good. the date on the trim tag is merely the date the car began being built. so assembly of the rearend prior to it would make sense. hope that helps.
SS69Chevelle is offline
post #3 of 4 (permalink) Old Jul 3rd, 06, 11:06 PM
You have the right dates but the wrong format. The year is only shown on the cast date not the axle assembly stamp.
0521 is (MM/DD) May 21st axle assembled day. B is Buffalo axle plant.
To find the axle cast date look at the center section facing the cover at
the 5 or 7 O'clock position. Will be a small "raised" not stamped code. A letter for month and numbers for day and last digit of year.
From this 70 list CCf is a 3.31 ratio posi
https://www.chevelles.com/years/70/70rearcodes.html
shooter is offline
post #4 of 4 (permalink) Old Jul 4th, 06, 1:40 AM
Donnie
Brian,
if your doing this for insurance, i would go with LaRue or Hagerty you both agree what your car is worth and you dont have to pay an appraiser $75 or a $100 bucks.
70 SS 396 Chevelle SOLD!
69 SS L-78 Chevelle
79 Z-28
04 GMC 2500HD Dmax/Allison
15 Wells Cargo 24' autowagon
07 Cadillac DTS
ACES #4390
Donnie1 is offline
This Thread is more than 5085 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Help Decode 72 Chevelle SS Posi 12 bolt rear Chevelle402ss Tag Team 10 Nov 30th, 05 3:47 PM
Rear End HELP for chevelle!!!!!!! egamino80 Brakes, Suspension & Steering 1 Nov 11th, 05 9:50 PM
Anyone ever see and 8.5 70-72 Chevelle rear? cobra2411 2005 19 Aug 9th, 05 4:29 PM
69 to 64 rear end swap question. Pat_McNeil Brakes, Suspension & Steering 3 Jul 1st, 05 9:18 PM
1970 Chevelle SS Rear seat. How much is it worth? ChevelleL88 Interiors 5 Nov 26th, 02 1:58 PM
