engine pad # - Chevelle Tech
post #1 of 4 (permalink) Old Jul 3rd, 06, 3:30 PM Thread Starter
engine pad #
I have pulled the engine out of my 69 chevelle to replace the freeze plugs and thought I'd check the numbers. the casting # is 3855961 which could be a late sixties 396 but the engine code has me stumped. To422edh the engine vin# 6a169746. Sisnct this does not match the car vin I'm assuming it is a replacement engine but what? Can any body help?
I have searching the threads and archives here for two days and gone to every link I could find but I don't find EDH any where.
JUST1QWK77 is offline
post #2 of 4 (permalink) Old Jul 3rd, 06, 3:43 PM
Re: engine pad #
Motor is a 66 396-325 HP Man-Trans. The H at the end of the ED Stands for Holley Equipped.
Mike Bond
ACES Charter Member #99
69 Chevelle SS396 Fathom Green
69 El-Camino SS 396 Black
L7870_cortez is offline
post #3 of 4 (permalink) Old Jul 4th, 06, 6:46 AM Thread Starter
Re: engine pad #
Thank you very much, this is my first chevelle and big block and I have alot to learn. I've had small block vettes for years but they are just to expensive now.
post #4 of 4 (permalink) Old Jul 4th, 06, 1:17 PM
Dale
Re: engine pad #
One thing you might want to know for the future if you ever need to replace the camshaft, 65/66 396 engines required a groove on the rear cam journal and rear cam bearing - much like the early 265/283 Chevys. Most 'off-the-shelf' cams for the 396 don't have this groove. In fact, most mfgs list their cams from 1967 and up because of this. Just something you might want to be aware of, don't order a camshaft for a 1969 Chevelle.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
This Thread is more than 5085 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Mystery Chevelle (MIKE) Look!!! Xplantdad Bench Racing 188 Aug 1st, 07 5:12 PM
marbles in engine??? jim poks Performance 21 Apr 27th, 07 1:38 PM
Front pad Engine #s 70SSconvt 2006 2 Jan 30th, 06 11:14 PM
installing engine - please HELP! New68SS 2004 6 Jan 28th, 04 6:23 AM
Need some info on LS-6 crate engine Zio 2004 12 Jan 12th, 04 10:57 PM
