"660" Muncie case ID tag decipher? - Chevelle Tech
post #1 of 9 (permalink) Old Mar 6th, 06, 8:25 PM Thread Starter
Sam
This tag is located on driver's side sidecover. Tag is affixed with the forward most lower sidecover bolt. It reads:
"3946798"
Transmission is in a '69 Chevelle. Manufacturers "P" code stamped on opposite side of case indicates an M21. Any help deciphering this is appreciated. I checked Colvins, but no joy.
Thanks.
Sam
mockingbird812 is offline
post #2 of 9 (permalink) Old Mar 6th, 06, 8:45 PM
Dale
Re: "660" Muncie case ID tag decipher?
3846798 is the Chevrolet part number of the trans. Fits:
69 Pass (close ratio w/P/Trac., 3.73 rear)
69 Chevy, Chevelle, Camaro (close ratio) w/3.55,3.73 axles (302,396).
The "P" simply indicates Muncie and not necessarily a specific M20/M21/M22 model. 69 and later Muncies were stamped with an ID code something like P9R25B for Muncie, 1969, October, 25, M21. I'd imagine yours is stamped similar; P9(letter/number)B.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #3 of 9 (permalink) Old Mar 6th, 06, 9:19 PM Thread Starter
Sam
Hey Dale,
Thanks for the reply. This car is a documented (POP, invoices, order form, etc.) 396, M21, 3.73 (CI) drivetrain Malibu SS. My reference to "P" code was merely an abbreviation. Actual is P9D03B. Interesting that the tag code covered more than one posi ratio in two performance motors. Thanks for the good info. This info wasn't on Chevelle Stuff was it?
Sam
Enclosed are the Pix (just figured how to link)
http://img.photobucket.com/albums/v6...2ULLfhX_ph.jpg
http://img.photobucket.com/albums/v6...2ySzBtP_ph.jpg
post #4 of 9 (permalink) Old Mar 6th, 06, 10:43 PM
Dale
A portion of it is. The part number itself came from my Chevrolet Parts & Accessory Catalog (circa 1971) I retrieved from the trash when I worked at a Chevy dealership in 71-72. Muncie decoding info came from: Quick Decoding Links > Muncie ID
* Author:
DaleM is offline
post #5 of 9 (permalink) Old Mar 6th, 06, 11:12 PM
Dale,
"Why do Muncie transmission codes begin with the letter "P"? Who knows..."
The P on the beginning of Muncie date codes stands for Passenger Muncie (truck Muncies begin with N).
This is straight out of the "early" Chevy parts books.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #6 of 9 (permalink) Old Mar 6th, 06, 11:28 PM
Dale
Originally Posted by DZAUTO
Dale,
Cool, Tom - thanks! I'll add that bit of information. Now, why do trucks begin with "N"?
* Author:
DaleM is offline
post #7 of 9 (permalink) Old Mar 7th, 06, 12:09 AM
Because they're Not a pass car???
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #8 of 9 (permalink) Old Mar 7th, 06, 12:21 AM
Dale
That just may be someone's logic at GM.
* Author:
DaleM is offline
post #9 of 9 (permalink) Old Mar 7th, 06, 1:00 PM
Hello Dale,I don't want to hi-jack the post but would you have any info on a tag of the side cover of the tranny with the no.3952659WB? It's in my 70 with 402 and 331 posi.Also in box 28 on build sheet it has the WB in that block.Thank you Dale, Greg.
chev crazy is offline
This Thread is more than 5245 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
