L78 69 Chevelle - Chevelle Tech
 3Likes
  • 1 Post By Saltherring
  • 2 Post By Steve R
post #1 of 8 (permalink) Old May 24th, 20, 12:11 PM Thread Starter
L78 69 Chevelle
What are the distinguishing features of an L78 Chevelle? If you don't have the documentation and you know the engine and transmission isn't original, how do you tell? I've heard it should have a 3/8 fuel line with no return, a 6000 RPM tach, what else? Any and all opinions are appreciated.
SSaywhn is offline
post #2 of 8 (permalink) Old May 24th, 20, 12:53 PM
Ole
Re: L78 69 Chevelle
If the engine is original it should have a Winters Foundry aluminum intake with a 780 vacuum-secondary Holley carb and numerous internal differences; i.e., four bolt main block, solid lifter camshaft, forged 11:1 pistons, HD 'dimple' rods, forged/cross-drilled/Tufftrided crankshaft and rectangular port heads. '69 L78 Chevelle engines will also have a unique 37 amp alternator P/N 1100837, a distributor P/N 1111499, deep groove pulleys, an 8-inch diameter balancer and a HD 3-row radiator with tag stamped IA XJ 28 BO (M/T only). Manual trans L78 cars are also likely to have either 3.55 or 4.10 rear gears. 4.10 gears have a KK code stamped on the front of the passenger side axle tube and 3.55 gears feature the letters KF.
0069SS likes this.
First Posted to TC as Ole Birkland in Feb 1999
Aces 3383
1969 Chevelle SS396, L78, M22, KK 4.10 posi, F41, Blue Light Stereo, Tilt Column, Burgundy/Maroon w/Red Stripe, Black Bench Seat, PS,
PDB, American Torque Thrust & BFG TA's, fully restored.
Saltherring is offline
post #3 of 8 (permalink) Old May 24th, 20, 1:40 PM Thread Starter
Re: L78 69 Chevelle
I could only wish the engine was original. Its confirmed a 76 Daytona Yellow SS, with a 4 speed. I've confirmed the fuel line as a single 3/8 line with no return, it has the KF I.D. for the rear end for the 3:55 gears and the 6000 RPM tach that is original. Just wish I had the build sheet. Appreciate your input. Thank you
ID:	627824   Click image for larger version
ID:	627826   Click image for larger version
SSaywhn is offline
post #4 of 8 (permalink) Old May 24th, 20, 2:07 PM
Re: L78 69 Chevelle
Unfortunately without the original drivetrain or documentation you will never be able make anything other than an educated guess. Even the presence of a 6000 redline tach and a certain size fuel line won’t hold much water since it can never be proven.
You are lucky it has an SS only paint color, calling it as SS and leaving it at that might be the best course of action. Once you go down the road of telling people it “might” be an L78 that will shift focus from what is verifiable to an abstract discussion based on a few, often odscure parts. That will tend to polarizes opinions and take away from the car.
Steve R
SSaywhn and IFLY like this.
Steve R is online now
post #5 of 8 (permalink) Old May 24th, 20, 3:23 PM
Ole
Re: L78 69 Chevelle
Mike, I was wondering why your water pump and alternator brackets are configured for a '66-'68 car, rather than a '69. The '69 model year 396 had the 'long' water pump and the alternator on the passenger side. I would suppose whatever engine is in your car was removed from a pre-'69 car and they just used the parts that came with the engine. I think there is an engine photo in my 'garage', if you would like to see what the correct '69 water bump and brackets look like.
I am not criticizing your car, I'm simply making an observation.
Aces 3383
post #6 of 8 (permalink) Old May 24th, 20, 6:38 PM Thread Starter
Re: L78 69 Chevelle
It was that way when I bought it. The previous owner bought the car in the early 80's and he stated it was this way when he bought the car as well. I'm sure the original engine is long gone by now. I'm just trying to puzzle the pieces together to find out exactly what I have. Car was painted in the early 90's to its current color. Its far from perfect but is driver condition which is what I wanted. Engine is from a 68 model car according to my research. You can see from the hole in the bell housing that its been ran hard at one time. Car still runs great, but it does have plans to going back to yellow at some point.
ID:	627832   Click image for larger version
ID:	627834   Click image for larger version
SSaywhn is offline
post #7 of 8 (permalink) Old May 24th, 20, 7:49 PM
Bruce
Re: L78 69 Chevelle
Obviously it was not built in Canada, but if it was originally sold in Canada you can get some info on it.
Our You Tube Vids:
NickeyChevelle is offline
post #8 of 8 (permalink) Old May 24th, 20, 10:17 PM
leo
Re: L78 69 Chevelle
from the engine stamps, it's a 68 engine and the IV and the end of the build date signifies it's a 396-325 engine from a full size chevy built at the Flint assembly plant. Good luck with your car and enjoy!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
