Date code on cast crank? - Chevelle Tech
  • 1 Post By 71350SS
post #1 of 4 (permalink) Old May 19th, 20, 8:58 AM Thread Starter
Are these a date code on this crank?
What does the N2 mean?
70 Chevelle SS454
454, 3964291 Heads, Manley Race Flo valves, Crane Valvetrain, 226/236 dur, 534/553 lift
Holley 750, Edelbrock RPM Air Gap, Accel ignition,
TCI TH400 B&M 3000 stall, 3.73 posi, Lakewood traction bars.
budsthe3 is offline
post #2 of 4 (permalink) Old May 22nd, 20, 10:56 AM
Re: Date code on cast crank?
Cant help with the N2. If the last number is a 6 in the date code it could be April 15, 66; April 15 76; or Apr 15 86. A '66 crank would have a grooved oil passage ground in the crank under the rear main cap, If it's a BBC.
Don't know if the Gen V parts were date coded.
What did the motor come out of? That will narrow down the date code.
Jayhawk500 is offline
post #3 of 4 (permalink) Old May 22nd, 20, 11:32 AM Thread Starter
It came out of a 1975 454, maybe it's not the original crank
70 Chevelle SS454
budsthe3 is offline
post #4 of 4 (permalink) Old May 23rd, 20, 3:41 PM
What is the part number on that crankshaft ? The part # will also give you a clue as to when it was made.N2 could probably be the code for the shift that did the work if they were running 2 work shifts when the crank was cast but that is just my guess.Someone who worked at Tonawanda or one of the foundry's may know better than I do.
Steve R likes this.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
