Vin is on block - Chevelle Tech
 2Likes
  • 1 Post By NickeyChevelle
  • 1 Post By jeffschevelle
post #1 of 9 (permalink) Old Mar 21st, 20, 11:50 AM Thread Starter
Vin is on block
Good morning and thanks for having me in your group, I recently acquired some either 396 or 427 blocks with one having a vin number on the block
T1007EJ6Z108727
Block number : 3855962
Hi Perf stamped
Heads are 3872702’s D56 and D266
So my question is how do I identify whether they are 396 or 427, and what does the vin number do for the block?? Thanks in advance, I have two of these blocks, one without a vin, can’t find or see it.
AJ Nieblas is offline
post #2 of 9 (permalink) Old Mar 21st, 20, 11:55 AM
Jon N.
Re: Vin is on block
EJ big blocks were 66 or 67 396's. 962 blocks were 65 or 66 396's.
castingnumbers.info/3855962
Jon N.
dyno jonn is offline
post #3 of 9 (permalink) Old Mar 21st, 20, 12:47 PM
& Administrator
Re: Vin is on block
The VIN on your block tells you it's a 66 vehicle, built at Freemont CA which built Chevelle (1964-1969, 1973-1975)
El Camino (1965-1969) ,Monte Carlo (1973-1975)& GMC Sprint (1973-1975).
The 108727 is the plant sequence number.
Mike is offline
post #4 of 9 (permalink) Old Mar 21st, 20, 3:51 PM
Keith
Re: Vin is on block
the EJ suffix code is a 396/360 with a 4 barrel carb, manual trans, AIR (K19). From a Chevelle or El Camino. the assembly date is Jan, 7th. what is the casting date?
Maryland Chevelle Club #682
keithb is online now
post #5 of 9 (permalink) Old Mar 21st, 20, 4:59 PM
Bruce
Re: Vin is on block
T1007EJ6Z108727
Hi Perf stamped
Heads are 3872702ís D56 and D266
So my question is how do I identify whether they are 396 or 427, and what does the vin number do for the block?? Thanks in advance, I have two of these blocks, one without a vin, canít find or see it.
Just offered as a clarification: The "T1007EJ" is the "date assembled and projected use" code that was stamped on the block at the Towanda (NY) Engine Assembly Plant. That code breaks down as follows: T = Tonawanda, 10 = October, 07 = the 7th day of the month, and EJ = 396 CID, 360 Horsepower, with a Manual Transmission. Therefore the engine is a 396 CID.
The partial VIN: "6Z108727" identifies a 1966 model year Chevelle built at the Fremont (CA) Final Assembly Plant. 6 = Model Year, Z = Freemont Plant, 108727 = the 8,727th Chevelle built at the plant in the 1966 model year. The partial VIN should match up to the VIN on your Chevelle/Title Card/etc.
24hrsparkey likes this.
Our You Tube Vids:
NickeyChevelle is online now
post #6 of 9 (permalink) Old Mar 27th, 20, 10:04 PM
Re: Vin is on block
Yes, Chevelle 396/360HP assembled OCTOBER 7 1965, not January 7 1966.
Also note that 66 Chevelle 396/360 engines used the 962 4-bolt main block prior to December 19 (or 20, can't remember which) of 1965. So you have a more desirable 4-bolt block there.
427L88 likes this.
Jeff Helms
-65 Z16 Survivor (Red/black/white int.) (
-65 SS Convertible (Red)
-66 SS L34/M20 Survivor Coupe (Aztec Bronze) - 'Vintage Legend' Certified (
jeffschevelle is offline
post #7 of 9 (permalink) Old Apr 3rd, 20, 10:43 AM
Re: Vin is on block
FYI --When I tried to open that link its says it was flagged and wouldn't let me open it.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #8 of 9 (permalink) Old Apr 3rd, 20, 11:13 AM
& Administrator
Mike is offline
post #9 of 9 (permalink) Old Apr 3rd, 20, 11:42 AM
Re: Vin is on block
The Chevelle this engine came from (108727) was probably assembled around the second week of November 1965, 11B.
25C 70 is offline
