Non oem 68 SS Chevelle engine ID CE block journey - Page 2 - Chevelle Tech
 6Likes
post #16 of 24 (permalink) Old Mar 22nd, 20, 9:15 PM Thread Starter
Re: Non oem 68 SS Chevelle engine ID CE block journey
Ok
Block casting date , passenger side near freeze plug / motor mount area.
These are cast in .
MAN THEY ARE ROUGH AND HARD TO READ , and upside down .
Q 14 8 Again super ruff cast in , not super positive about any of them .
Sorry.
Engine assembly date , starter pad . I assume they are stamped in.
Still cannot find stampings , on the starter pad or surrounding area. I will have to pull the starter to get a total view of the area. Not a huge deal , except I was stupid enough years ago to run the new trans cooler hard lines under the starter trapping it . Arrg.
Thanks all
1968 396/325 SS Chevelle Car. Non original 427 engine now.
24hrsparkey is offline
post #17 of 24 (permalink) Old Mar 23rd, 20, 4:46 PM
Dale
There is no "Q" month, probably "G" for July.
Here's a sample of the warranty engine date stamp.
https://www.chevellestuff.net/qd/eng...mp_numbers.htm
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #18 of 24 (permalink) Old Mar 23rd, 20, 8:34 PM Thread Starter
Thank you sir for your help
post #19 of 24 (permalink) Old Mar 24th, 20, 2:42 PM
In post # 15 you mentioned getting the cyl head numbers.Remove the valve covers and the head #'s will be around the middle of the cyl head while the heads casting dates will be between cylinder # 5 and 7 or 2 and 4 on the other side that's IIRC.
24hrsparkey likes this.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #20 of 24 (permalink) Old Mar 28th, 20, 9:09 PM Thread Starter
Well i popped off the drivers side valve cover and got some info
Hi Perf
GM4T
3919840 ( 9s and 8s are hard to distinguish but I think I got it right )
F18
Any info greatly appreciated
Thank you
post #21 of 24 (permalink) Old Mar 28th, 20, 9:16 PM
Dale
3919840 - late 67 thru 69 L78 heads.
F18 - June 1, 1968
https://www.chevellestuff.net/qd/hea...ng_by_year.htm
* Author:
DaleM is offline
post #22 of 24 (permalink) Old Mar 28th, 20, 9:48 PM Thread Starter
F18 - June 1, 1968
Thanks !!
So knowing what we know about the block .
Did these heads come on it
Or
Did someone put really good heads on a lower performance block
Hmm
post #23 of 24 (permalink) Old Mar 28th, 20, 11:33 PM
Here's the information listed from the out inthe shop web site.
3935439---427---68-69----2 & 4-Bolt
If you have the tapped fittings above the oil filter more than likely it's a 4 bolt main but the only really sure way is to look inside the oil pan.
71 El Camino SS
71350SS is offline
post #24 of 24 (permalink) Old Mar 30th, 20, 11:08 AM Thread Starter
Soo just to re cap and consolidate all these numbers .
Front Engine ID Pad CE950409
Back of engine :
3935439 Block casting #
G 14 8 Block cast in date
***** assembly stamped in date not found yet
Cylinder Heads
Hi Perf
GM4T
3919840
F18
Engine has a solid cam . Type or manufacturer unknown.
Only one oil pressure tap off , right above the oil filter. Most Not all 4bolt main blocks have 2 OP tap offs for an oil cooler .
My recollection of seeing / finding it was a 2 bolt main cap block Many years ago while changing the oil pan
Soo 99% of the info has been gained , with all your help.
Ill Never know what car model this CE block was installed in . A shame , i wanted to know.
To me all this info boils down to this
I have a 427ci , 390 or 400 Hp 1969 block that someone put 1968 good squareport iron heads onto.
Open to opinions and corrections please
thanks 24hrsparkey
