72 Build Sheet Code Questions - Chevelle Tech
 5Likes
  • 2 Post By Cam
  • 1 Post By LTJOHN
  • 1 Post By LTJOHN
  • 1 Post By DaleM
post #1 of 12 (permalink) Old Mar 7th, 20, 8:01 PM Thread Starter
I have a 72 Malibu build sheet, found it in the back seat. I can decode most of it by searching previous post and on Chevelle Stuff but I'm unable to find some information and looking for help.
U63 AM Radio, is there a code or package that would show if it had rear Speakers and also if it had a radio with Fader control?
PL2 E78x14 B/WAL 2&2 Box #56 Wheel Trim, just has a BW and .. . 3 dots? Black Walls with Hub Caps?
Other boxes just have a number and a code, example Box 42 has AZ, Box 75 has a K.
Not that its going to matter much but I'd like to get the interior back to as close to original as I can and curious about the others.
LTJOHN is offline
post #2 of 12 (permalink) Old Mar 15th, 20, 5:30 PM
Re: 72 Build Sheet Code Questions
It's always helpful to know what factory your car was built at.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #3 of 12 (permalink) Old Mar 21st, 20, 5:05 PM Thread Starter
Sorry, I stopped checking for responses after about 5 days and got consumed by the other stuff going on. KC Build, AC car. When we got the car it had a blue light special radio (K-Mart Sparkomatic) That went into the trash. All I could find locally that worked was a
U80. I don't know if it will run both front (2 front AC car) and rear speakers. That's why I was looking for a code for speakers.
U63 AM is 7933241 Delco# 21APB1
U80 AM is 7933501 Delco# 21APBK1 W/Fader
Wheel trim I'm not sure about...not able to find P01 ,P02 or PA3 on the sheet.
Name:	Build Sheet.jpg
LTJOHN is offline
post #4 of 12 (permalink) Old Mar 21st, 20, 8:20 PM
Cam
Cameron Milne
Hey, you've got factory D88 stripes on a non-SS Malibu!!!
I just see U63 on the build sheet plus C60 a/c so I'm wondering if it was the same as 1970 models in that you would get a pair of front speaker on the dash, operating in mono. It was done due to clearance for the center a/c duct. Normally just a single central speaker in the front.
Judging by the equipment and noting the absolute base tire with no optional wheel equipment (no P01, P02 ZK7 or whatever) it sounds like whoever ordered your car was planning on mags or something. Why not? I know several people back in the 70's that ordered their Camaros with all the goodies they wanted, plus base tires with dog dish caps (one got Cragar SS wheels, the other got big Rally Wheels).
71350SS and 24hrsparkey like this.
"The more you know,
TC Gold #120
Cam is offline
post #5 of 12 (permalink) Old Mar 21st, 20, 10:06 PM Thread Starter
Ok, so the U63 only had the 2 front speakers, AC car. The non AC cars you'd get 1 front and 1 back, U80 w/fader? It's got the 2 front but both have bad voice coils. Someone installed 4ohm kick panel speakers and wired them all together....can't do that.
I did find some hub caps on Chevellestuff. #994138 that appear to be the ones the car had, still had 2 of them on it when we got it.
It also had dual exhaust.
LeoP likes this.
LTJOHN is offline
post #6 of 12 (permalink) Old Mar 21st, 20, 11:37 PM
Cam
Cameron Milne
Sounds good! The L48 was only single exhaust in 71/72 for Chevelles & Montes. Probably one of the first things addressed on your car by the original owner. Heck, in 1972 it would be in style to install a set of Thrush Outsiders side-pipes on day 2. Or headers with Purple Hornies header mufflers.
The hubcaps would be the kind known as Rally Moons. They look like Baby Moon hubcaps but had the Chevy bowtie stamped in the center. Debuted on 1970 Camaros and extended to Novas & Chevelles for '71. Last used on '73s.
I also notice YF8 on your build sheet. Not only did your Malibu come with D88 stripes, they specified the alternate color (black) over the default (white) with your paint combo. Er, what color was your '72 originally?
"The more you know,
TC Gold #120
Cam is offline
post #7 of 12 (permalink) Old Mar 22nd, 20, 8:52 AM Thread Starter
53 Placer Gold. It had the Thrush mufflers on it ( My choice back in the day ) but not the side pipes, stock exhaust manifolds.
Original motor but not the tranny. 12 bolt 2:73
LTJOHN is offline
post #8 of 12 (permalink) Old Mar 22nd, 20, 2:53 PM
Dale
Red face Re: 72 Build Sheet Code Questions
* If rear speakers were ordered they would show in box 107 as U80 AUX RR SPEAKER
* Box 56 is for the standard E78x14 blackwall bias tires and since no optional wheel or wheel covers are present it would have standard hubcaps. That's confirmed by the wheel color in box 79 that matches the lower body color. Chevelles with no optional hubcaps ordered had wheels painted same as lower body color; those with option wheel covers were painted black.
*As for the other broadcast codes such as those in Box 42 and 75, different plants used those for whatever they thought the affected workstations needed to know as they are not labeled with any specifics.
* For example, of the 47 1972 non-SS build sheets I have data on from KC, 8 have AZ in box 42 (along with AN, AV, BR, BS, CF, CH, CM, and CR) and is found on base Chevelle sport coupes, Malibu convertibles, Malibu El Caminos, and Monte Carlos. All with L48 engines but I have three L48 engines with AN instead.
* I have 25 72 KC non-SS sheets with K in box 75 but, again, a variety of models (13437, 13637, 13669) and a variety of engines. FWIW, neither Baltimore nor Van Nuys put anything in box 75.
Confusing, eh?
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #9 of 12 (permalink) Old Mar 22nd, 20, 3:45 PM Thread Starter
Thanks Dale, yep a bit confusing...
The wheels on the car did have the lower body color.
Actually what you stated makes sense that some boxes or blocks would hold specific information for different plants.
Box 23 Exhaust CF?? Crossflow? I know on some the lead pipe would join up with the passenger side right after the tranny. Just curious, it's going to have duals when it's done.
71350SS likes this.
LTJOHN is offline
post #10 of 12 (permalink) Old Mar 22nd, 20, 4:19 PM
Dale
CF is just a broadcast code, not an abbreviation or acronym. Other exhaust broadcast codes used we CP, CD, CG, GF, etc.
71350SS likes this.
* Author:
DaleM is offline
post #11 of 12 (permalink) Old Mar 22nd, 20, 4:35 PM Thread Starter
Ok, thanks again Dale!!
LTJOHN is offline
post #12 of 12 (permalink) Old Mar 22nd, 20, 7:12 PM
Speaking of that gearing : My 68 SS chevelle had the 2:73 posi and a vacume gauge on the automatic trans shifter console .
I was about 17ish .
Did not know any car came with that autobahn gearing .
BUT that explains why it would go 63mph in 1st and bury the speedo in second. Again I was 17.
Also explains the first time to 75-80 dragoway . Only used 2 speeds and had a miserable time slip. 15:50 . Arrrg.
Carry on gents .
1968 396/325 SS Chevelle Car. Non original 427 engine now.
24hrsparkey is offline
