1971 Chevelle Build Sheet codes - Chevelle Tech
 10Likes
  • 2 Post By Steve R
  • 1 Post By blue_69_malibu
  • 7 Post By KBentzen
post #1 of 12 (permalink) Old Oct 7th, 19, 5:10 AM Thread Starter
Question 1971 Chevelle Build Sheet codes
Hi
I just bought a 1971 Chevelle and found the Build sheet under the backseat. Is there any gurus in this forum which can explain the different codes used in this sheet? Please see the attached photos of the laminated sheet.
Anything special about this car?
ID:	604950   Click image for larger version
ID:	604952   Click image for larger version
ID:	604954   Click image for larger version
KBentzen is offline
post #2 of 12 (permalink) Old Oct 7th, 19, 7:08 AM
re: 1971 Chevelle Build Sheet codes
Whatís special about it is that it has survived.
Steve R
blue_69_malibu and 12stones like this.
Steve R is offline
post #3 of 12 (permalink) Old Oct 7th, 19, 8:32 AM Thread Starter
Steve R
Hi
Thanks for quick answer.
Thats whats nice to know. Which codes specifies this is just a standard model? Im not expecting to have struck gold here, just want to learn "nice to know" facts.
KBentzen is offline
post #4 of 12 (permalink) Old Oct 7th, 19, 8:39 AM
I canít decode the specific boxes, there are others that can. Based on whatís listed AC seems to be the only option that might not be considered common.
Steve R
Steve R is offline
post #5 of 12 (permalink) Old Oct 7th, 19, 11:17 AM
This will get you started
https://www.chevellestuff.net/1971/index.htm
https://www.chevellestuff.net/1971/bs.htm.
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
post #6 of 12 (permalink) Old Oct 8th, 19, 12:43 AM
Dale
Looks like a pretty basic V8 Malibu sport coupe. Mulsanne Blue, blue vinyl top, blue cloth/vinyl bench seat. 307-2 with TH350. Very late December start of the build, probably finished early January.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #7 of 12 (permalink) Old Oct 8th, 19, 12:46 AM
How about some pix of your '71?
Steve R likes this.
blue_69_malibu is offline
post #8 of 12 (permalink) Old Oct 8th, 19, 1:34 AM
Since you found the buildsheet under the back seat it must be a pretty complete car.If you can't put up a picture,what kind of shape is it in ? Are you going to restore it back to stock ? or do you plan to modify it some ?
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #9 of 12 (permalink) Old Oct 8th, 19, 3:27 AM Thread Starter
Red face re: 1971 Chevelle Build Sheet codes
Nice. It have a 350 Goodwrench now. Probably replaced in the late 80s. The vinyl top have been removed. Probably in the same time. Thanks for the information.
KBentzen is offline
post #10 of 12 (permalink) Old Oct 8th, 19, 4:01 AM Thread Starter
Hi
Ofcourse I can post pictures of the car. It have has a respray sometime in the 80s and the engine is a Goodwrench. As you can see the vinyl top have been removed. Its a strong car with a nice paintjob. Some rust in the trunk area, but the rest is solid.
The winter is closing in here in Norway so it will probably be sitting in the garage up untill next year. Gives me good time to tinker with it. The wheels are going to be replaced as I do not like aftermarked wheels. Standard Rally 8x10 with sentercap and trim ring will be next on the list. Its all about making the car look as original as possible.
Thanks for the help regarding the decoding.
Cold Idle:
Warm Idle:
I just bought this car so I will be active on this forum and learn as much as possible about this car. Been looking for a classic car for 10 years now, so this is not a impulse buy
ID:	605036   Click image for larger version
ID:	605038   Click image for larger version
ID:	605040   Click image for larger version
ID:	605044   Click image for larger version
David Bates, Steve R, LeoP and 4 others like this.
KBentzen is offline
post #11 of 12 (permalink) Old Oct 8th, 19, 4:10 AM
Congratulations on your purchase. Itís a nice looking car. I hope you enjoy it.
Steve R
Steve R is offline
post #12 of 12 (permalink) Old Oct 10th, 19, 12:38 AM
Re: 1971 Chevelle Build Sheet codes
Your '71 is beautiful, but it appears to be a '72. Was the front end replaced with '72 parts at some point?
spoffie1962 is offline
