I or a lower case L on a casting date? - Chevelle Tech
post #1 of 6 (permalink) Old Aug 7th, 19, 8:16 PM Thread Starter
my spare 66 12 bolt has what looks like a casting date of l 30 5. reading some old posts I saw that GM didnt use the I because it could be mistaken for a 1. so it should be a L for November even though it doesnt have the lower horizontal part of the capital L? jim
Jim Mac is online now
post #2 of 6 (permalink) Old Aug 7th, 19, 9:46 PM
Re: I or a lower case L on a casting date?
The I was used on some parts, but not others. It was used on the axle pumpkins (and L means December on an axle). At least that is true for 64-67, I can't say for sure on 68+
Jeff Helms
-65 Z16 Survivor (Red/black/white int.) (
-65 SS Convertible (Red)
-66 SS L34/M20 Survivor Coupe (Aztec Bronze) - 'Vintage Legend' Certified (
jeffschevelle is offline
post #3 of 6 (permalink) Old Aug 7th, 19, 10:23 PM Thread Starter
so this would be a Sept 30 1965 rearend then. jim
post #4 of 6 (permalink) Old Aug 9th, 19, 4:51 AM
Dale
"L" is used as a casting month on most items; alternator, heads, engine block, intake manifold, exhaust manifold, starter, water pump, etc. The letter "I" was not used on engine blocks but was used on most everything else including rear-end housings.
https://www.chevellestuff.net/qd/rear_axle_info.htm
The letter "I" is often used on engine build stamp date stamps in lieu of the number "1" but often both may be used at the same time on a date. I've seen an LS5 engine with an engine stamp of T1I2I (tee, one, eye, two, eye). and TI1I2 before.
TC Gold #92 ~ August 1998
* Build Sheet Data Collection
* Author:
DaleM is offline
post #5 of 6 (permalink) Old Aug 9th, 19, 8:56 AM Thread Starter
So would Sept 30 rear end be a late 65 or early 66 rear? Jim
post #6 of 6 (permalink) Old Aug 9th, 19, 11:38 AM
Dale
Early 1966. The 1966 model year began production in August of 1965.
https://www.chevellestuff.net/1966/plant_prod_no.htm
* Author:
DaleM is offline
